Results 1 to 17 of 17
Thread: New Pool owner - Up swamp creek without a paddle
    Sep 2015
    Illinois
    5
    Just last week, my family & I just purchased a 20 year old forclosed home with an inground pool. No one knew any history about the pool - other than the pump & filter, (and most likely a natural gas heater) system is completely missing. It's a 34'x16' liner pool with currently a nasty swamp full of algae and frogs.
    I am not worried about installing a heater system for forseeable future, but I've already got my hands on a Hayward SP2610X152S pump and I am still trying to get a 24" Sand Filter asap. My problem is, I don't understand the piping schematic on my pool. I have been thinking about calling the local pool outfit, but I am hoping that I might find more sound professional advice here at TFP.
    I've got what appears to be three separate flex conduits of 230V. I've got a capped off natural gas line, and 1.5" & 3/4" PVC piping - with sand residue inside of one of the 1.5" pipes. I understand that the 3/4" piping would have been for the heater system, but it doesn't seem to make much sense. My friend thinks that the drain side would be coming off of the 3-way valve - but after doing some online research, I believe the drain is coming off the piping on the left side.
    Any thoughts?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: New Pool owner - Up swamp creek without a paddle
    Greetings and welcome from a fellow foreclosure swamper
    Fortunately, mine had come with equipment, but here's a pic that might help u as I suspect our set ups are similar:
    Hi again, had to switch to iPad to post the picture:
    On mine, there's the skimmer line and main drain line.
    Someone with authoritative equipment knowledge is bound to come along and weigh in, but I wanted to welcome you and subscribe to your thread in the event you need assistance with the swamp part once you get the equipment up and running.
    Its a good time to go ahead and get a TFP-recommended kit, either the Taylor k2006 or TFT100 specifically so that you can test properly to clear the swamp
    And even without equipment running, you can start testing out debris, which will eventually help you get control of swamp creek
    Cheers to clear!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    PS...don't be confused by that extra 3rd line...it goes to a sump under my deep end well that I can pump out by closing off the other lines.
    Helpful Links:
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    How many skimmers do you have? They will be towards the top of the pool. May be rectangle in shape with a basket inside of it.
    We can help you I bet. Just give us time and info. while we work through it.
    Kim
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I would agree that your guess on the pipes on the left should be suction, Skimmer & MD. But question, can you confirm how many skimmers & drains are installed?
    Does the pool have any water features such as a waterfall or water slide?
    With 3 power feeds, one for the pump, one for the heater and maybe one for a booster pump for a cleaner?
    I have limited heater knowledge as my oil fired heater in not that mainstream, but it uses the same size 2" piping as the rest of my install. I would think 3/4 for the heater would be restrictive but i could be wrong. As Swampwoman said someone(s) with strong equipment knowledge should jump in shortly
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Sep 2015
    Illinois
    5
    Quote Originally Posted by EVChargeGuy View Post
    I've only got one skimmer box, no waterside or waterfall or anything special. With the condition of the water in the pool, I have no way of telling how many drains it has.
    There are three severed conduits, but I didn't verify how many of them are 230V. I think at least one of them might be 115V.
    Sep 2015
    Illinois
    5
    Quote Originally Posted by Swampwoman View Post
    Cheers to clear!
    Thanks for the response! Glad you were able to get past your own forclosure mess....I bet it felt good to finally get a clean pool!
    Coincidently, my pool is also a grecian style.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Were there any poles or other stuff like that laying around anywhere? You are going to need a pole, leaf rake and brush. You will want to start digging the gunk from the bottom as soon as you can. Even though you can't see it, you'll be surprised what you find in there!!
    Leaf Rake example: pool_rake.jpg
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Cool -- also forgive my ipadian typing, I meant NETTING out debris, not testing
    But I want to give you the test kit link...fastest shipping IMHO: http://www.tfttestkits.net
    SO soon your Grecian can go like this
    Helpful Links:
    Jul 2012
    Tallahassee, FL
    30,585
    Post a link to your first thread as well. It was quite a neat one filled with lots of lessons!
    Kim
    Sep 2015
    Illinois
    5
    I tried calling the local pool company that takes care of my area, seeing if they had any advice for me & to possibly set up an appointment for service.
    The guy I talked to mentioned something about draining my pool, and I asked if he knew anything about the local water table. He said yes, it very high in our area - as high as 4 feet below the ground. He went on telling me about how he caved in his own backyard liner pool multiple times and had to fill it in. After we got that sad & embarrassing story out of the way, (without even missing a beat) he then casually advised me to go ahead and drain my pool because the water in my side of town probably isn't as high. His reasoning - my windowless basement isn't flooded.
    Back to my pool...
    I thought about using an air compressor to look for bubbles in the pool to figure out where my water lines are actually going. It sounds like a foolproof idea, but I am afraid that my pool is already winterized. (it appears to be - from the best I can tell).
    Wouldn't I risk blowing out my jet caps, etc - if I used an air compressor to test out my piping?
    Jul 2012
    Tallahassee, FL
    30,585
    "I sure will drain my pool after you JUST told me your have messed up your own pool!" Yea that is the ticket! NOT!
    Can't help you with the other question. Sorry
    Kim
    Sep 2015
    Illinois
    5
    Thank you for the link. I will definitely buy that kit before next season.
    Love the pool, I hope to get mine looking exactly like it someday.
    Jun 2014
    15,221
    Grego556, looking at your post where you said:
    I thought about using an air compressor to look for bubbles in the pool to figure out where my water lines are actually going. It sounds like a foolproof idea, but I am afraid that my pool is already winterized. (it appears to be - from the best I can tell). Wouldn't I risk blowing out my jet caps, etc - if I used an air compressor to test out my piping?
    I would tend to agree with you that pushing some air through might be a good idea. At least to confirm your overall suction/pressure sides. Since the house is a foreclosure, I don't see how it could've been properly winterized yet, especially if the water has not been lowered a bit yet. Besides protecting the equipment from a hard freeze, the other reason we winterize is to make opening in the spring easier for you with no or little algae, and that's obviously not an issue since it's a swamp already. I would push some air through so you can at least begin to re-route the plumbing the want you want to for your new equipment. That's my 2-cents.
    Oh, and here's the winterizing link that may come-in handy later for you too: Pool School - Closing an In Ground Pool
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Greggo, you're in Il. Take the lid off your skimmer to see if there's a "gizmo" in it...that will help you know if its been winterized or not gizmo looks like a bottle type plug used in the skimmer to avoid freeze harm.
    Also, Texas, just so you know, Fanny Mae/Freddy Mac DO have a schedule of expenses for pool closure in season, so the representing realtor MAY have had it closed and been reimbursed for same
    Helpful Links:
    Jun 2014
    15,221
    Ooh, that's interesting. Perhaps their contracted closing methods are a bit different that ours. The Gizmo check definitely is a good idea.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    You should be able to identify where the skimmers are by looking at the pool deck. Take off the skimmer cover and remove the basket. If you don't want to reach your hand down in there to feel around for the opening in the bottom of the skimmer (suction line) use a stick to poke around and see if there is a plug in the line. If you find the suction line is open, run a water hose down in there, turn on the tap, and watch for where the water comes out. That will be the suction line at the equipment pad. Mark it with a sharpie.
    You will probably find the line on the left is the suction, since it has two pipes with valves feeding into 1 pipe. To me that indicates a main drain and a skimmer. Have you tried just opening those two valves to see if anything flows out? The line with the sand residue is probably where a bump type DE filter used to live. My guess is due to the fact that bump DE filters usually have the discharge line on the bottom. Cartridge filters also discharge from the bottom but usually won't have residue in the line. The two reduced lines may have gone to a pressure side cleaner and a SWG or a water feature.
    You can feel around the sides of the pool about a foot down to try and locate the returns and see if they are plugged.
    Love TFP? Become a
    TFP Supporter!
