Thread: And the water level goes... here?
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Okay, so closing time for my pool. The difference this year is that I added a Hayward skimmer, so I'm not sure which of the following I should do:
    1) Should I drain the pool 6" below the skimmer, leave the skimmer in place (except plumbing) as well as leave the old return in place (The Red Lines). This seems like it would help support the skimmer (once all the plumbing was detached since it would have more water in it.
    OR...
    2) Drain the pool 6" below the old return, so I can clean out anything that has accumulated in that little pocket over the season (The Orange Lines)? This would allow me to thoroughly clean the old, capped return, but I'm concerned the liner won't support the skimmer well with the water that much lower.
    Thoughts, opinions, ridicule all welcome.
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
    Casey's Avatar
    SW PA
    10,444
    Re: And the water level goes... here?
    Personally, if it were my pool, I'd unscrew that capped return, take the hoses off the skimmer box and cover the pool. Your pool cover is going to displace pool water during the fall n winter months from rain water. Just keep an eye on it. I go out and check my pool monthly, even during the coldest winter months just to make sure everything looks normal, cover isn't buckling walls, skimmer box is in place etc..... Just don't put the cable of a pool cover under that skimmer box. I've seen them destroy pools by doing that.
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Thanks!
    May 2012
    Montville NJ
    545
    While I don't have an intex, I leave my pool full for the winter. I put a plate on my skimmer and plug my return. I see no need to drain my pool down for the winter, as long as I remove any rain that accumulates.
    For what it is worth, what I would do with your pool is drain it down to the red line, unless you can put a plate or plug in the skimmer on an Intex - I don't know if there are issues with that. If you are worried about the capped return having "Stuff" in it, just unscrew the cap, let a gallon or two of water run through it, and then cap it again.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
