Results 1 to 7 of 7
Thread: Replaced Barrcuda X7 with ThePoolCleaner
    Jan 2010
    Spring Texas
    47
    I have a 4 year old Barracuda X7 that worked fairly well. My pool continually catches Palm tree berries, magnolia leaves and lots of other leaves. The barracuda X7 diaphragm continually stops up and will not move. I just had to clean it out a lot.
    I saw on the forum ThePoolCleaner was highly recommended. I bought the 4 wheel version, snapped it together and threw it in the pool. I timed the rotations of the tires and it was close enough. It's been a week and every inch of the pool is spotless and I have done nothing except empty the leaf catcher. Not one blockage and it has not gotten stuck.
    I just threw the barracuda in the trash, wish I had done this years ago.
    20000 gal in ground Pentair Screenlogic 2 ez-touch 4
    Teledyne heater Compupool 40k Salt generator
    Pentair VS pump Hayward 4025 Cartridge Filter
    12 person Spa The Pool Cleaner robot
    lot of bushes and trees close to the pool
    Jun 2014
    15,153
    Re: Replaced Barrcuda X7 with ThePoolCleaner
    Nice feedback. I'm sure someone will benefit. We get cleaner questions all the time. Have a nice weekend.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    I wonder if that barracuda would have worked better than my pole and $10 vacuum head, haha.
    Thanks for the review - someday I'll be in the market for one and the PC seems like the cat's meow.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jan 2010
    Spring Texas
    47
    Yes that works, but my wife revolted when I force her to vacuum the pool. The magnolia leaves do not decompose but they turn hard, waxy and stiff. The PC sucks them right up.
    susa's Avatar
    Oct 2010
    Deep South
    578
    We use the 2 wheel version of the Poolvergnuegen and had to only replace the rubber surfaces every couple years, otherwise everything seems to last for years and cleans well.
    JoyfulNoise's Avatar
    May 2015
    13,213
    I seem to remember PoolVernugen was bought up by Hayward. Isn't the ThePoolCleaner by PoolVernugen now called some other name by Hayward?
    Matt
    Apr 2015
    So. Cal.
    139
    Yes...they are owned by Hayward and they have three versions with color being the only difference in the Hayward models. The "next generation" The Pool Cleaner... Then there are two versions with the Hayward name on it. Both Hayward models havean integrated handle and also have updated wheel hubs.
    One version is called the Hayward Phoenix (gray, white, and blue) and only available at Leslies.
    The other version is the Aquanot (black, white, and blue).
    All available in 2and 4 wheel drive.
    The only thing im seeing consistent is the replacement of tires from them wearing out. Wondering if the 4wheel model would last linger because it gets better traction all around...
    Im getting rid of my kreepy krauly and ordering one of these up. Right now they are offering a $75 rebate along with a free leaf canister.
    Just debating on the 2 vs 4wheel drive models. I was recently advised to go with the 4wd model if i run off the skimmer at on end of the pool. Cost difference is only $20.
    Cant wait!
    13000 Gal rectangle gunite w/Aqua-Glass IG lap pool built in 1987 resurfaced (Aqua-Glass) in 2010, Hayward Max-Flo VS pump (model SP2302VSP)
    Rheem Gas Heater 266,000 BTUH (P-M267A-EN-C), Hayward Pro Grid D.E. Filter model DE3620, ThePoolCleaner, CoverPro safety pool cover, TF-100 test kit w/SpeedStir
