Results 1 to 12 of 12
Thread: Greatings from the Sunshine Coast, Australia.
    AUSpool's Avatar
    Sep 2015
    355
    Geday from the the Sunshine Coast, South East Queensland, Australia.
    I've found myself hear while searching for pumbing solutions for an energy efficient solar pool heater. I've always been up for a bit of DIY and have a bit of experience with pvc pressure pipe fittings having kept a saltwater aquarium for over 15 years. I have a Bsc in Chemistry and Biology (Aquatic Resources Management) but don't used my Bsc degree for my employment.
    First question, where's the best place to ask a question about plumbing for me solar heater?
    Regards to you all, Steve.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Greatings from the Sunshine Coast, Australia.
    Hi, welcome to TFP! The Pumping Station would be the place to ask your question. I guess y'all would be about on the edge of summer now!
    Love TFP? Become a
    TFP Supporter!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Really, we're pretty open, so wherever is fine. If you must pick a spot, I would point you towards "Everything else" Seems like a lot of solar heater talk there.
    well there you go. two possibilities! Pick one and ask away!!
    And WELCOME!!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2014
    15,008
    Welcome to TFP Steve. Hope you find what you need here.
    AUSpool's Avatar
    Sep 2015
    355
    Thanks for the welcome everyone.
    That was a really quick reply but I didn't think that while its morning hear (Thursday) it's early evening for everyone else, and yesterday (wednesday). So who believes in time travel now ah.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    One of my work colleagues works in Japan. I've gotten used to adding 13 hours to what my clock shows. So right now it's 9:00 PM on Wednesday evening. What time and day is it for you?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    AUSpool's Avatar
    Sep 2015
    355
    Quote Originally Posted by zea3 View Post
    Thanks for that, I'm still editing a quetion in pages so I'll post something up a bit later.
    Yep, its spring but summer is just around the corner. Were a bit differnt down under, celcius, centimeters, meters, litres, but different is good ah.
    Steve.
    30,000L (8,000g) Pebblecrete | Davey 3sp Eco pump | Poolrite sand filter & SWCG |
    Waterco solar panels & Astral E140 pump| K2006, BlueDevil pH, Salt meter & K1766 | Town water - pH 7.2, TA 50, CH 60 | Esky full of coldies |
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    buy all your 40mm pressure pipe from bunnings
    cheapest i have found
    and use pink primer and green glue for pressure pipes
    hint if you use pn12 pipe you can use 32mm pressure pipe for internal joiner
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    AUSpool's Avatar
    Sep 2015
    355
    Quote Originally Posted by pabeader View Post
    We're an hour ahead of Japan so that would make it 12 hours ahead, I was 9:00 AM Thursday.
    Steve.
    AUSpool's Avatar
    Sep 2015
    355
    Quote Originally Posted by aussieta View Post
    Thanks ausieta, another Aussie.
    Bunnings prices are pritty close to Home Depo, especially with tax and the exchange rate. I just bought back a bag of elbows and tees from Lowes, CA store. 40mm is 11/2" and 50mm is 2".
    Thanks for the tips, I've never thought of using an internal joiner, wouldn't that decease the flow a bit though?
    Steve.
    aussieta's Avatar
    Jan 2014
    488
    some of the plumbing can be a bit tight and need an internal join
    doesn't make much difference to flow
