Results 1 to 9 of 9
Thread: Bought house with pool, question on closing.
    Sep 2015
    Bloomington IN
    27
    Hello,
    Iíve tried to do my homework, but Iíve still got questions now that Iím doing my homework on winterizing.
    Pool water looks great. Previous owner used the 3Ē chlorine pucks in the skimmer and just tested with the red and yellow drops.
    I plan on closing per the Pool School info. However, I have a question about ďSLAMmingĒ. I planned on using bleach.
    Do I have to buy the big test kit before I can even figure out how much to add?
    Bill
    14000 Gal, Vinyl Lined Pool, No salt
    Jul 2015
    Kentucky
    1,127
    Re: Bought house with pool, question on closing.
    Hello Bill, and Welcome to TFP,
    To answer your question.
    It will be impossible to properly SLAM your pool without one of the recommended test kits. You can get the TF 100 at http://tftestkits.net/TF-100-Test-Kit-p4.html
    or
    Taylor k-2006 sold at several places online and some of your local pool stores may also sell them.
    IMO the TF 100 is the better kit for the money, but either will work. Getting one of the recommended test kits will be one of the best investments you will ever make for your pool.
    It is amazing how much one test kit can help you accomplish in getting your pool clean and clear, and keeping it that way. I hope this helps, and have a nice day
    EDIT: Bill you can figure how much you need to add by using the pool math calculator http://www.troublefreepool.com/calc.html, but the thing is with the other test kits you won't be able to check the higher levels and ensure it is being maintained there at all times.
    What we generally do is recommended that you merely add 1/2 to 1 gallon of bleach a day until your kit arrives and then adjust the levels accordingly when you are able to accurately test them.
    You'll want to try to ensure your pH is adjusted to around 7.2ppm before increasing your chlorine levels too much, as the pH testing after the chlorine level gets above 10ppm will no longer be accurate. END EDIT
    Last edited by Crackerjack4u; 09-23-2015 at 12:50 PM. Reason: additional info added.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Apr 2015
    South Central PA
    298
    You will likely need to measure 12+ ppm of chlorine (depending on your CYA level)...the drop tests don't go that high, and even if they did, they read a rather broad range as opposed to a specific number from the DPD test.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Sep 2015
    Bloomington IN
    27
    Quote Originally Posted by Crackerjack4u View Post
    END EDIT
    OK, thanks for the help. I'll order a kit. I've been using the 3" pucks in the skimmer. The yellow and red drops have been reading OK. Are you saying I should dump a galloon of bleach in everyday? I'm not planning on shutting the pool down for a few weeks yet.
    Bill
    Jul 2015
    Kentucky
    1,127
    Hello Bill,
    After looking back on the above comments, I think I may have been misreading exactly what you were actually wanting to know about "SLAMming". In the actual pool closing process wording I'm almost sure the "SLAMming" your questions were referring to are actually in regards to the word "SLAM" for 2-3 days before closing section, in the actual Closing The Pool LINK. Is that correct?
    If that's the case then NO, you do not need to add a gallon of bleach or anything per day right now, but about 2-3 days before you Winterize you will bring your pool up to shock levels getting it ready for the Winter.
    Pour the bleach slowly in front of the return, with the pump on, After you've poured the bleach in, then brush the area below where you poured it in to ensure none settles on the bottom, then continue per the rest of the winterizing directions.
    I hope this helps answer it correctly this time. I'm so sorry for the confusion. Feel free to ask any other questions you may have. I'm pretty sure I am finally on the same page with you now . Have a wonderful day.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Me too!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    Kentucky
    1,127
    You too what BOB did you misread it also?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Exactly. My response was shorter than yours but pretty much the same. You got in before me so I just said "Me too"
    Jul 2015
    Kentucky
    1,127
    Gotcha
