Results 1 to 7 of 7
Thread: Pool water not flowing consistently
    Sep 2015
    Houston
    8
    Hi, I just bought a house with an in-ground pool. I noticed the pool water was not flowing consistently the day before yesterday. Water flows rapidly for like 10 seconds, then gradually slows down to a complete stop, then flows rapidly again. This goes on and on. Is this something wrong with my pump?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: Pool water not flowing consistently
    have you looked at your pressure gauge when it does this?
    Dolphin E10 Cleaning Robot.
    Sep 2015
    Houston
    8
    Yes, the pressure goes high and low repeatedly
    Jun 2011
    Long Beach, CA
    2,784
    What is happening in the pump basket? Look for air bubbles.
    30,419
    I am pretty sure you will have the bubbles in the pump basket.
    Pump running, go to the skimmer and see if your water level in the pool is lowenough to allow the skimmer to suck air. If so, add water to the pool and it will stop.
    Sep 2015
    Houston
    8
    Thank you! So all I need to do is to add water to the pool, right?
    I have not checked the pump basket. Will do it when I get home. If there are air bubbles what should I do? Thanks!
    Quote Originally Posted by ping View Post
    domct203's Avatar
    Jun 2015
    CT
    3,583
    Welcome to the forum.
    Quote Originally Posted by sysdtc1988 View Post
    No, you need to check the water level first as Dave suggested.
    ........Pump running, go to the skimmer and see if your water level in the pool is lowenough to allow the skimmer to suck air. If so, add water to the pool and it will stop.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
