Thread: Checking in from the muggy and buggy deep south
    Sep 2015
    pass christian/mississippi
    2
    Hello everyone,
    Recently had my pool installed and was enjoying my maintenance free pool(ignorance is bliss, not)and life until I discovered(thanks to some nasty looking water) a little attention to detail may be in order. Well it didn't take long to realize the local pool shop guy was not the answer, so in my search for knowledge I found ya'll (you all ). This site is filled with so much information and knowledge it is truly a blessing. Now I am back to enjoying my pool and life( except for the darn PH issues).
    Andy
    35k saltwater IG rectangular plaster/gunite with pressure side cleaner and fountain,
    Pentair 1.5 hp Challenger pump/Pentair tr100 filter, Pentair IC40 swcg, Pentair intelliph,
    Pentair 1 hp Challenger pump(fountain),Pentair booster pump.
    Jul 2015
    Kentucky
    1,124
    Re: Checking in from the muggy and buggy deep south
    Hello Andy, and Welcome to TFP,
    It's nice to hear that our method is working as well for you as it has so many others, and lol I agree the pool store method is rarely ever the answer.
    You mentioned you're having a pH issue if you'll post a full set of levels perhaps we can help you get that taken care of too.
    What test kit are you using? We recommend the TF 100 or the Taylor K2006 here at TFP as those are the only 2 kits that have the reliability to allow you to properly check, and properly maintain your pool levels . so if you don't have one of the recommended test kits that would be a good place to start.
    The TF 100 can be purchased at http://tftestkits.net/TF-100-Test-Kit-p4.html, and the Taylor K2006 can be purchased at several places online and some of your local pool stores may also sell them.
    Once you list us a complete set of levels we'll go from there on helping you get that pH issue resolved.
    Here's a good little link that might be of interest to you too. http://www.troublefreepool.com/conte...ater-chemistry
    Feel free to ask any questions you may have a long the way. Again welcome to TFP, and have a wonderful day .
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,421
    Andy! HI! So glad you found us! Your wallet will be glad also!
    Let us know about your PH issue. I am sure we can help you.
    Kim
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Also second one of the test kits that Crackerjack4u mentioned. In the meantime, here are some resources to give you an overview of managing your pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
    Sep 2015
    2
    I use the taylor 2006 test kit. On the PH stuff I guess I have one of those pools that ph just wants to climb all the time. I add 18 ozs a day of muriatic acid to keep it around 7.6- 7.7 and keep my TA on the low side around 60-70ish, calcium probably not high enough but around 300.
    Jun 2014
    15,008
    pH will continue to climb on you with that new plaster. That could go on for months. Between the plaster, your SWG, and any aeration you have (fountain) pH will continue to be a battle. Keep acid nearby to effectively lower the pH between 7.2-7.8. From time to time, look closely at the CSI numbers listed on the Poolmath calculator when you enter all your info (pH, TA, CH) to make sure you are within acceptable CSI levels of -.6 to .6. That plays an important role in your water management.
