Thread: Strange chlorine issues
    Sep 2015
    St Lucia
    1
    Hello,
    I need help.
    My in ground tiled pool is 12000 gal and the water is presently at 88F. I'm using a sand filter.
    I'm using a Taylor K-2600 testing kit
    I have what I believe a mustard algae infection.
    I have been throwing about 16 gal of liquid chlorine at 6% with no effect on the chlorine level except that the water looks much better.
    I can now see the bottom of my pool.
    Yesterday I tested again everything. Almost no chlorine, PH: 7.6, TA: 100, CYA: 60 then had 4 gal of liquid chlorine
    This morning the water looks a bit clearer, almost no chlorine, PH: 7.2, TA: 100, CYA: 60
    What should I do next???
    Bruno
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Strange chlorine issues
    You need to follow the SLAM process the key is staying on top of your testing and your FC level, this may mean several times per day.
    Pool School - SLAM - Shock Level And Maintain
