Thread: Will an SWG still produce chlorine with the "inspect cell" lit?
    Jun 2015
    Ottawa/Ontario
    339
    Subject line says it all. Closing pool in a week.
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Will an SWG still produce chlorine with the "inspect cell" lit?
    Hi,
    Yes. The SWG will still make chlorine with the inspect cell lit, providing the 'generating chlorine" light is still on.
    The inspect cell light comes on every 90 days whether it needs it or not. The message can be cleared. Check your owners manual for how.
    Divin Dave,
    Jun 2015
    Ottawa/Ontario
    339
    Thanks!
    Clear the blinking inspect cell light by pressing the diagnostics button for a few seconds.
    If the light is not blinking but solid, then there might be a problem.
    Can you post the diagnostic readings?
    Support the site
    Jun 2015
    Ottawa/Ontario
    339
    Sure. Will do tonight when i get home
