Thread: Used wrong cylinder
    Aug 2014
    Tampa
    37
    Used wrong cylinder
    I accidentally used the "other than chlorine" cylinder to test chlorine. Have I ruined that cylinder for other tests, or is it the chlorine test that gets compromised if done in a cylinder that's been used for other tests? The "chlorine only" cylinder has only been used for chlorine tests.
    Thanks.
    IG concrete, 14'x24', 11k gal
    Paper cartridge filter, 1hp 2-speed pump soon
    [8] Heliocol panels harvested from a solar electric customer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: Used wrong cylinder
    Just rinse it out. It's fine.
    The chlorine only cylinder tends to get discolored with time is all.
    30,431
    +1 what 320 said.
    Aug 2014
    Tampa
    37
    OK great, thanks for the prompt responses guys!
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    On that note, I recall a thread or two with folks being able to clean that Chlorine Only cylinder...with MA, perhaps? I have little black specks all over mine.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
