Thread: Winter Cover Size Question
    Jul 2015
    Manalapan / NJ
    6
    Hello .. this is my first year closing my 15 x 30 AGP. The winter cover that was given to us at the time of purchase is a 18 x 33 cover. I wrestled with that thing to two days to pull and stretch it over the pool posts. Its on but it just seems too small and tight. I would think one heavy snow storm and that thing is going to rip or pop off.
    My question is if there is any downside to getting a cover sized for a 16 x 32 pool? This way I know for sure that the cover will be big enough to survive winter snow and rain.
    Thanks for your help
    10.6 K; AG; Hayward Pro Series Sand Filter (S210T); Hayward 1.5 HP Power Flo Matrix Pump (SP1593FP); Hayward Aqua Trol SWG (Turbo Cell T-5); Built 7/9/2015.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Re: Winter Cover Size Question
    Is your AGP round or square?
    If you close with the water 1' below the top of the pool, than add 1' on each side (therefore needing 2 feet). Recommend you have 2 feet hanging on the side as well. This would be 6' extra. So, the cover you had was bigger for a reason. Bungee cords work well together and there is no need to make them too tight. Because of cost, you may want to get a thick strong rope, create loops at the end and then work with the cords. This is probably what I would do.
    You have to decide how much slack you want to have. The more in the pool the less wear and tear on the cover from heavy water, snow pulling cover down. Also, if you have rip in the cover it will go down a little further in the pool, so definitely a little slack is best. Also recommended that you purchase a small pump to pump water off the cover. Eventually you will not be able to if it snows a lot and freezes. Leave a little water 2" on top of the cover to hold it down.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
