Thread: High bromine and ph and alk dropping a bit
    Jun 2015
    Oklahoma City, OK
    72
    OK, I thought I had this all figured out and had control of my levels the last couple months. Then, we bought new bromine tablets from Wal-Mart instead of dumb spa place. These are obviously much more potent or something because we haven't had to use NEAR as much bleach after being in the tub. So, we just stopped using as much bleach....no biggie. However, the bromine just keeps going higher even with no bleach being put in. 5 days ago, bromine was at 6.25, up from a 5 the day before. I turned down my floater because it had been open almost all the way with the old bromine tablets. Tested again tonight and it was 12.5 when my husband tested it. He made me retest and I got 10 (not sure why the difference). I have read about ozonators and possibly not needing a floater, but I needed it before with the old tablets, so I am confused there. I also read about keeping the floater tied up instead of circulating. Would that make a difference? Nobody has been in the tub for over a week, so we haven't had bather load, but it always still needed bleach every few days before.
    Also, my ph and alk were down to 7.0 and 30, so I raised them last week. Does the higher bromine affect those levels?
    Thank you for any advice! I'm a bit frustrated since I had a handle on things before!
    1000-gallon Master Spas H2X Swim Spa. Installed June 2015.
    Started with chlorine and it went south (with awesome advice of spa dealer....insert sarcasm).
    My kids ended up with bad bacterial hot tub rash 10 days after installation.
    Dumped it and started over with bromine.
    Re: High bromine and ph and alk dropping a bit
    Tabs are net acidic. They will lower pH and TA. Different tabs dissolve at different rates. The new tabs are probably dissolving much faster than the old ones. Remove the feeder until the bromine level is good.
    Support the site
    Jun 2015
    Oklahoma City, OK
    72
    Quote Originally Posted by JamesW View Post
    Thank you!
