Thread: Hayward ColorLogic problem
    Sep 2014
    Clarksville, Tn
    42
    My inground vinyl liner pool is less than 1 yr old. I have 2 Hayward colorlogic lights. Yesterday I was in the pool with scuba equipment(just playing around getting ready for an upcoming trip). While I was in the pool the timer for the lights came on. One light was on fine and the other was not. As I swam near it I saw a dim red light flickering inside the light. I could see there was water maybe 1/3 way up in the light housing. I also heard a "clicking/ticking noise underwater near the niche. I got out right away when I heard that but felt no shock or anything. After I got out I tried turning lights on/off several times but still same. Then I turned the "all off" button on my remote off and everything(filter, lights, etc) went off but I still saw the red flickering light in that light. Is this a bad light or something really dangerous?
    My pool builder is out of business(REAL long story). I am awaiting a call back from Hayward after I called the helpline and was on hold 15 minutes.
    TikiP- 18x36 IG Vinyl/Steel freeform shape. 3.5 to 6 ft deep.
    Hayward 270 Sand Filter, 1.5 hp pump, 300K BTU Hayward propane heater, Tiger Shark cleaner, 2 Colorlogic LED lights. 2 skimmers, 2 main drain, 4 returns , 4 brass deck jets, Maldives artificial rock waterfall, Hayward 40K salt generator. 1400 sq ft paver deck and coping. Tiki Hut and Bar.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,027
    Re: Hayward ColorLogic problem
    Howdy,
    I dont have the answer to your question, but figured a reply might bump it back to the top. Hopefully someone who might know will come along.
    Divin Dave,
