Thread: Hayward Pro Grid Pressure Valve
    Aug 2015
    Saint Cloud FL
    3
    So my pressure relief valve is leaking from the very tip where air/water would exit when one opens the valve. I ordered this to fix it... Amazon.com : Hayward CCX1000V XStream Cartridge Filter Manual Air Relief Valve : Swimming Pool Filter Valves : Patio, Lawn Garden
    Can someone verify this part does unscrew from the assembly? It seems pretty darn tight and I don't want to break the housing. Forgive my childish paint skills.
    Jun 2015
    Wildomar, California
    423
    Re: Hayward Pro Grid Pressure Valve
    Yes it does unscrew, hence the male thread. But do it carefully, things do break
    Aug 2015
    Saint Cloud FL
    3
    Thanks OPM
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    The large part unscrews from the top by turning about a 1/4 of a turn. Gently rock it out of the tank top. there are two piston seal orings. Once the large piece comes out there is a nut underneath the large part that you use to remove the air relief on the top of the large part.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
