[COLOR=rgba(0, 0, 0, 0.701961)]I'm new to this site, so I haven't been using your recommended system of water treatment. But, I've been a pool owner for 11 years, so I don't get "stumped" very often. But I am now.[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]I have cloudy green water, but the chemicals seem to be in balance. A day or two after cleaning the filter cartridges, the water began clouding. A few days later, it turned blue-green, and now it's just green. I first noticed the clouding on Sept 5, so it's been about 2 1/2 weeks since the problems started.[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]I tested the water, and it was normal, so I took a sample to the pool store for them to test. They said it was perfect. They recommended using fewer chlorine tablets in the floaters, and adding a clarifier, neither of which helped. [/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Then I thought perhaps my filter cartridges were worn out and had developed holes. I replaced them, ran the filter for about 3 days, and saw no improvement. I took the filter apart again to inspect for damage, and couldn't find any. [/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]I shocked last night, and here's what my water test says today (Aquachek 7 test strips):[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]FC 5[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]CC 5[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]pH 7.8[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]TA 120[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]CA 250[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]CYA 100[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Here is the pool store's analysis from a week ago:[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Total chlorine: 10[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Free chlorine: 10[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]pH 7.6[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Alkalinity: 90[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Hardness: no test[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Cya: 50[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Phosphate: no test[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]What do you think? Is it a problem with the filter, or the water? Or both?[/COLOR]
[/COLOR]
[/COLOR]
[/COLOR]
[/COLOR]
[/COLOR]
[/COLOR]
