Results 1 to 8 of 8
Thread: Cloudy green water, water chemistry maintained, what happened?
    Sep 2015
    Dallas, TX
    2
    [COLOR=rgba(0, 0, 0, 0.701961)]I'm new to this site, so I haven't been using your recommended system of water treatment. But, I've been a pool owner for 11 years, so I don't get "stumped" very often. But I am now.[/COLOR]
    [/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]I have cloudy green water, but the chemicals seem to be in balance. A day or two after cleaning the filter cartridges, the water began clouding. A few days later, it turned blue-green, and now it's just green. I first noticed the clouding on Sept 5, so it's been about 2 1/2 weeks since the problems started.[/COLOR]
    [/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]I tested the water, and it was normal, so I took a sample to the pool store for them to test. They said it was perfect. They recommended using fewer chlorine tablets in the floaters, and adding a clarifier, neither of which helped. [/COLOR]
    [/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]Then I thought perhaps my filter cartridges were worn out and had developed holes. I replaced them, ran the filter for about 3 days, and saw no improvement. I took the filter apart again to inspect for damage, and couldn't find any. [/COLOR]
    [/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]I shocked last night, and here's what my water test says today (Aquachek 7 test strips):[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]FC 5[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]CC 5[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]pH 7.8[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]TA 120[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]CA 250[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]CYA 100[/COLOR]
    [/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]Here is the pool store's analysis from a week ago:[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]Total chlorine: 10[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]Free chlorine: 10[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]pH 7.6[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]Alkalinity: 90[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]Hardness: no test[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]Cya: 50[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]Phosphate: no test[/COLOR]
    [/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]What do you think? Is it a problem with the filter, or the water? Or both?[/COLOR]
    30,000 gal. chlorine pool, 20 years old
    in-ground gunnite
    filter: Jandy CL460 cartridge, cleaner: Polaris 360
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cloudy green water, water chemistry maintained, what happened?
    Welcome to TFP!
    Algae is always a chemistry issue and never a filter issue. You aren't keeping enough chlorine in the water for your CYA level. You really need accurate test results to know the appropriate path. CYA is unlikely to change 50ppm in a week.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Like John said- You need accurate test results. This is only possible with your own test kit. I suggest either the TF-100 or the K-2006C available from TFTestkits.net
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2014
    15,080
    In addition to what JohnT mentioned, you might want to consider the following:
    - The proper test kit (i.e. TF-100 or Taylor K-2006) is the foundation of your pool care. We've learned through personal experience that you cannot reply on pool store testing, test strips, or simple over-the-counter kits. They simply do not read Free Chlorine (FC) or Cyanuric Acid (CYA) levels accurately or to the high levels we need. If you do not have a TF-100 or Taylor K2006 test kit, it should be your #1 priority HERE.
    - Green/cloudy water means you will need to "SLAM" (not shock) via Pool School - SLAM - Shock Level And Maintain. But you must have the proper test set noted above.
    - Floaters, tablets, pucks, and bags-of-shock many times do more harm than good, especially to your CYA. Please see the TFP list of Pool School - Recommended Pool Chemicals.
    Until you can get the proper test kit, simply consider adding about 1 gallon of regular liquid bleach to your water each day. Generic is fine from Wal-Mart of HEB. When you receive the proper test kit, post a full set of numbers and we can help you prepare for a "SLAM". Hope this helps. Welcome to TFP!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Texas beat me to the punch!!
    Sep 2015
    Dallas, TX
    2
    I will order a new test kit today! Thanks for the help. And sorry about the weird formatting in my first post. I won't cut and paste again.
    in-ground gunnite
    Jun 2014
    15,080
    No problem. We'll keep an eye out for your next post once your kit arrives. Don't forget to ask for the "Speed stir". That makes testing a breeze. Have a nice day.
    Aug 2014
    Shallotte, NC
    693
    Awaiting the test kit............................
    Have you put anything else into the pool? Like an algaecide? Or other chemicals?
