Results 1 to 7 of 7
Thread: Shelf life of liquid chlorine
    May 2008
    massachusetts
    8
    Anticipating the end of the season here in the northeast I have a five gallon excess of liquid chlorine (12.5%).
    Can I store this for any length of time or will it loose its oxidation qualities?
    Thanks, Max
    JoyfulNoise's Avatar
    May 2015
    13,249
    Re: Shelf life of liquid chlorine
    Quote Originally Posted by maxhouse View Post
    Thanks, Max
    It'll be salt, lye and water by the time you use it next year. The high % LC degrades pretty quickly. It should be typically used within 2-3 months of the date code.
    If it's closed, will a local pool store take it back?
    Matt
    May 2008
    massachusetts
    8
    Thanks Matt.
    May 2015
    13,249
    See this this page for half life info.
    Matt
    Oct 2013
    Iowa
    82
    I had 4 gallons extra last year which I stored over the winter. While they were not quite the same as new 12.5% in the spring, they were still more effective than 8%, I believe they were close to 10%. The key is keeping them cold, they spent most of the winter in the shed, unless sub-zero weather threatened, then they moved to our unheated but attached garage which stays 30-40 when it is really cold out. The half life is a lot longer for cold temps.
    20,000gal in-ground 16x36 sentry pools vinyl liner, Pentair sand filter, Pentair minimax NT heater, auto-cover, Polaris 280 cleaner.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    You can use them around the house (laundry, cleaning needs) but more sparingly than you do the normal 8.25%.
    Mar 2007
    San Rafael, CA USA
    12,082
    See this post for tables of breakdown for 12.5% chlorinating liquid and 8.25% bleach. This is for high-quality product. Some brands may break down more quickly if they are not careful in using water free of metals.
