Results 1 to 8 of 8
Thread: How to put safety winter cover on?
    Sep 2015
    nj
    4
    Question How to put safety winter cover on?
    Hey guys,
    So I'm at the last step of winterizing my pool -- putting the cover on! but boy am I having trouble! I've never closed a pool before (just moved into a house with the pool) so still learning as I go. Can someone explain to me the technique for putting this cover on?
    I've got a rectangular shaped in-ground pool with an area that comes out for the steps. I dragged the cover out over the water with the side that had a knotch cut into it for the steps placed down at that end. Now the problems that I ran into were:
    1.) Water starts getting on top of the cover and it starts getting heavy... is there a technique to avoid that?
    2.) How on earth do I hook these springs up into the anchors that are in the ground!? I took an Allen key and pulled the anchors up out of the ground but wasn't able get the springs hooked on both ends of the pool, the tension was too tight!
    3.) What order do you hook the springs on? Entire left side first? Or go back and forth from left to right side of pool?
    4.) I noticed not every spring has an anchor in the ground. Should it? Or are these covers made sort of generic so they don't always match up?
    Thanks!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How to put safety winter cover on?
    There is a tool to attach the springs. It's like a piece of pipe with a notch cut out of the end. See it at Amazon.com : Loop Loc Spring Installation And Removal Tool - Stainless Steel : Swimming Pool Covers : Patio, Lawn Garden
    I put a spring on an anchor at one end, then put the opposite one on at the other end of the pool. That starts to hold the weight. Then work from that one until you can get a pair on the other side of the short end attached. That will give you full support of the weight. Then you just work your way around.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    If you run some ropes across the pool tied down to a few of the anchors it help keeping the cover above the water until you attach some of the springs
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Oct 2013
    Iowa
    82
    The first year I tried to put our cover on I almost lost it in the pool. After that I searched around and applied what I learned and I can do it fairly quickly by myself now. The technique I use is to unfold the cover onto the pool attaching every other spring as I go. I alternate sides when attaching the springs, which leaves enough slack I can attach them as I go without using the tool yet, but it still supports the cover enough to keep the water under it. Then I come back and attach the rest using the tool, that also lets me make sure it is centered, etc before I get it all strapped down tight. I go back and forth when attaching the final springs too so as not to pull the cover too far one way, but I might be overly picky about it, without a helper it does involve a lot of walking around.
    I thought the covers were custom and should have an anchor for every spring. I can't explain why you wouldn't, but maybe if you detail how many and which spots do not have anchors someone else would have an idea there.
    20,000gal in-ground 16x36 sentry pools vinyl liner, Pentair sand filter, Pentair minimax NT heater, auto-cover, Polaris 280 cleaner.
    May 2013
    Long Island NY
    419
    I put my loop loc cover on our 16x32 by rolling it out on one long side and since it was folded like an accordion it's ready to go. I hook each corner on one side, then grab the strap for the opposite corner and pull and run and latch that corner.
    Now I have just one more corner to hook. The cover is in the water by now and I have to walk and pull and work myself down to the last corner. Once that one is hooked the rest are easy. I use one of those 3' long steel cover tools that came with my cover.
    You can also lay the pool cleaning pole across the pool midway to keep the cover from sinking. I don't do that anymore since I perfected my method.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Every spring should have an anchor. Sometimes, two springs go on one anchor.
    Support the site
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    443
    I just helped my Dad close his pool. He has had a safety cover for about a decade and I bought one last year. Needless to say, it is easier with more than one person and we had more than one tool as well. First things first. It is virtually impossible to install the safety cover without the pipe-looking tool. Second I agree with dfahrion. Unroll the cover, and attach every other loop to its anchor. There may not be an anchor for each spring. Depending on the shape of your pool, some springs may share.
    We are doing my pool this weekend.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    canpool's Avatar
    Jul 2013
    Canada
    41
    good youtube video's out there. here's one ..
    How to Install A Swimming Pool Safety Cover - YouTube
    Kafko 15x28 Rectangle granite grey liner pool - Kafko 8 foot granite grey steps / Kafko 8 foot granite grey sunledge - Hayward Equipment - Kafko Safety Cover - Beachcomber 750 hot tub
