Thread: Question about skimmer plugs
    Apr 2014
    United States
    21
    Hi, last year I used a rectangle skimmer plug when I closed the pool last year and the skimmer leaked. I prefer to not drain the pool below the skimmer as it is already a
    strain on my well to fill the pool in the spring. Should I purchase a new rectangle plug or buy a plug for the bottom of the skimmer? I've never used one of those plugs with the wing nuts. Would it expand in the cold and break the plastic on the bottom of the skimmer (where the hose hooks up to run to the pump). Hope this makes sense, thanks.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Re: Question about skimmer plugs
    Please add your signature
    If possible, can you please take a picture of your skimmer and the plug that you are referring to? Which State are you in? What exactly leaked in the skimmer?
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
