Results 1 to 9 of 9
Thread: Capacitor continuously fails
    Sep 2015
    Caledonia/Ontario
    2
    I have a two speed Hayward pump that has the AO Smith motor on it. Have replaced the capacitor and the new one isn't working. Didn't work right away. i have replaced one before and it worked for about two weeks before it failed again.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Capacitor continuously fails
    Time for a different brand of capacitor, I think.
    Or make darn sure you are getting the correct size one for your motor.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    22,553
    Do you have a centrifugal switch on the motor? If so, it could be that the switch isn't making contact and that's what is keeping the motor from starting.
    Sep 2015
    Caledonia/Ontario
    2
    Quote Originally Posted by Agent99 View Post
    I got a direct replacement for the original.
    I dont know if i have a centrifugal switch on the motor. It does hum and then not start when switch turned on. Then it goes into the protect mode. I replaced the capacitor the first time and good for two weeks then I went and bought new one. Didnt work at all. Pump hummed and would nt start. It starts manually with screwdriver at base. Spins free with no apparent binding.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Maybe try a different source for your caps. They age just sitting on the shelf, so if your dealer has old stock it could be the source of the problem.
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    Try to get a capacitor that is made in Japan, not China. There's a difference. If not that, then it might be an issue with the motor itself.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    Jun 2015
    Wildomar, California
    423
    Or,maybe the motor has a short in the winding, a loose wire on the back plate or... If the motor was reassembled, a wire is pinched somewhere.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    What model of pump do you have? I may have an answer.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Sounds like a sticky centrifugal switch to me.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
