Results 1 to 15 of 15
Thread: When should we close the pool?
    Sep 2015
    Montreal, Canada
    12
    Hi,
    I wonder when should we close the pool? Should we wait till the night temp falls below zero?
    I'm from Montreal and it seems that the temp is still above zero for a few weeks. Any guys from Canada here?
    Mine is inground liner.
    Many thanks.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: When should we close the pool?
    You can close any time the average water temp for the day is below 60 degrees (Fahrenheit) or 15 degrees Celsius.
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Announcements - has links that should answer any closing questions.
    Aug 2015
    Montreal, Quebec, Canada
    36
    Hello fellow montrealer,
    ill be waiting to close mine until the temperature goes down to 60.
    Previous years, I closed in october and everything went well for the start up the following year.
    44000L oval above ground vinyl pool ---Taylor K-2006----
    Jacuzzi Saniclear 20 salt generator, Waterco XLRU50btu Heat Pump
    Jacuzzi L192 19" sand filter, Jacuzzi 1.5hp pump
    Pool School + Test Kits + PoolMath = Happy Times
    If in doubt SLAM - Shock Level And Maintain + Perform the Overnight FC Loss Test (OCLT)
    canpool's Avatar
    Jul 2013
    Canada
    41
    Hello fellow Montrealer as well,
    We keep our open as late as possible as well. Once temps drop I unplug the salt module and keep the pump running a few hrs a day to continue circulation until the beginning of October. At the same time I install our loop lock cover to keep the leaves out.
    When it's time to close I just fold back the cover to do 1 final vacuum and have the full closing of pool and heater done.
    Had a good swim weekend this past weekend. Hopefully get 1 more weekend in atleast.
    Kafko 15x28 Rectangle granite grey liner pool - Kafko 8 foot granite grey steps / Kafko 8 foot granite grey sunledge - Hayward Equipment - Kafko Safety Cover - Beachcomber 750 hot tub
    Sep 2015
    Montreal, Canada
    12
    Thanks. As this is my first pool, is it difficult to close the pool myself? Should I pay someone to do it? What is the ballpark price for that in Montreal? Pool is inground liner, 50000 L, pump inside cabana with bottom and skimmer drainage with sand filter.
    Thanks again.
    Inground liner 15,000 gallons in Montreal, Canada
    Aug 2015
    36
    I wont cost much if you do it yourself. Is it a new pool or did you buy a house wuth an existing pool? Cuz usually the old owners will already have a cover (thats what costs the most)
    This will help Pool School - Closing an In Ground Pool
    Will you be putting a cover? and water bags? These can be bought at club piscine. I recommend the one in Laval (on autoroute 15). They have the biggest selection of stuff i have seen.
    You can get the polyquat and antifreeze at club piscine.
    May 2015
    Quebec, QC
    37
    I close when temperature is below 10 Celsius. Between now and closing date, I keep the solar pool cover on to minimize chlorine and evaporative losses and circulate an hour a day, just to redistribute the chlorine. After lowering the water level to 6 inches below the return, I put away the solar cover, and replace it with a water permeable black mesh cover. To keep the mesh from touching the water, I use a system of ropes that criss-cross the pool. I remove the mesh once the surface freezes, usually by the first week of November, and before any major snow storms appear.
    I do not have a bottom drain, so do not use anti-freeze. I do blow all the lines using a shop vac, empty the sand filter, remove the pressure gauge and cap all lines in the pool. Finally, to minimize water volume in the skimmer, I add compressible plastics to the empty skimmer body.
    14 x 28 Jacuzzi vinyl inground pool, Jacuzzi Laser 250 sand filter, Hayward 1 HP pump.
    canpool's Avatar
    Jul 2013
    Canada
    41
    I wasn't home last year upon closing. This is just our 2nd year and don't feel 100% confident yet undertaking the task. If I recall, it's in the $200 range. Not sure as first closing was free. I'll find out this week as I'll be booking our closing and report back if the cost is off base ..
    Might be better for you as well to have it closed this season and 'hover' around the tech. to learn the tricks of the trade!
    Sep 2015
    Montreal, Canada
    12
    Quote Originally Posted by Paul. View Post
    Thanks, it's old pool and the previous owner left everything for me including the cover. It seems that he did it himself before.
    Quote Originally Posted by Eauclaire View Post
    Thanks. For the temperature, you mean the night temperature or the day temperature?
    Quote Originally Posted by canpool View Post
    Thanks, please update me about the price. Sure I don't feel confident either but still think DIY is fun (and of course cheap) so I might give it a try.
    domct203's Avatar
    Jun 2015
    CT
    3,584
    Quote Originally Posted by tffool View Post
    .........Thanks. For the temperature, you mean the night temperature or the day temperature?.......
    Water temp. Once the pool water is staying below 60F algae growth is extremely difficult.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Sep 2015
    Montreal, Canada
    12
    Quote Originally Posted by domct203 View Post
    Dom
    Thanks, but when should I take the water temp? Day or night? Sorry for stupid question...
    domct203's Avatar
    Jun 2015
    CT
    3,584
    During the day when you expect the pool to be at its peak temp.
    There are no stupid questions here at TFP.
    Dom
    Dom - TFP Guide
    canpool's Avatar
    Jul 2013
    Canada
    41
    ok just booked closing. $195.00 for in ground pool closing (I will install safety cover myself) cheers.
    Sep 2015
    Montreal, Canada
    12
    Could you PM me the company info?
    Thanks.
