Thread: Winter cover for above ground pool completely surrounded by wood deck
    Sep 2015
    Greer, SC
    1
    What is the best way to cover a round above ground pool completely surrounded by wood deck? There is no space between deck and pool. Can I use a regular round above ground cover and just anchor it down with Aqua blocks or water weights? Also has anyone had success with the drain which installs in middle of cover?
    18'x52" round above ground pool completely surrounded by wood deck
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Winter cover for above ground pool completely surrounded by wood deck
    Welcoming you to the forum, and sorry you haven't got an answer. I'd think that a good idea with a full deck around the pool. Add a water pillow underneath, or get a good cover pump so it won't hold water. Perhaps a bump to your question will get some replies. Lots of folks here have AG pools and they'll make some suggestions. Enjoy the forum!
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    I'd check and be sure that cover has enough "overlap" to it where you can do what you propose.
    Jul 2014
    Hope Mills, NC
    566
    I have seen safety covers for above ground pools with decks, the straps attach to the deck framework and hold the cover to the top of the pool.
    I can guarantee that if you use the cover/water bag method you will be spending a long day cleaning the mess that accumulates between the cover and the deck. My concrete is permanently stained...bought a safety cover this year and threw out the water bag cover.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
