Thread: New pool-aqua rite question
    Sep 2015
    Allen,Texas
    4
    I am in the process of interviewing pool builders in the Dfw area. One of them mentioned a new interior finish called aquabrite. Said it came with a lifetime warranty and chemical load would be reduced. Anyone out there have information or have this in there pool. If so do you think this is better then a pebbletec type product? Any advice would be appreciated thanks.
    Aug 2015
    Houston
    7
    Re: New pool-aqua rite question
    looking at their page I like the idea of it but it is basically a plastic/fiberglass applied to the concrete. The biggest issue I have is it is new and therefore somewhat untested over time.
    http://www.ecopoolfinish.com/aquabright/
    IG pebbletec 21k gallon with cartridge filter Jandy VSP 2hp pump and a 15' 12" wall with 3 scuppers. one skimmer, one floor drain all independently piped with 2.5 in lines.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    how much cheaper is it than pebbletec finish? no reason a properly installed pebbletec finish shouldn't last you 10-15 years (if not more) assuming water quality is kept up.
    the finish is not going to have an impact on chemical load, other than a new pool having pH rises. but that's easily handled with additions of muriatic acid, and its cheap too.
    the finish looks nice, are you able to see it installed in a recent pool? if you like the way it looks and the price is right, then you should consider it. just don't base that decision on manufacturer issued pseudoscience there is a lot of incorrect info on their website "selling" the product. like I said, go see it in person and make your decision based on if you like it or not.
    more important is what equipment is in your bid specs? I would recommend posting a full list here for input. there are usually a ton of things the pool builders like to add on that are not needed or wanted (I.e. UV systems, mineral packs, ozone, etc) and sometimes important things that are missing with plumbing, etc. we have a lot of knowledge here, use it to your advantage.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Sep 2015
    Allen,Texas
    4
    Thanks daninfla. Right now I am getting bids. My pool will be about the same size as yours. Can I ask how often you run your pump/swcg?
