Thread: What type of Chlorine do I enter for Pool Math
    May 2015
    Union, NJ
    128
    What type of Chlorine do I enter for pool math? I have a SWG and the type of Chlorine produce is not an option on the drop down for pool math. Any help will be appreciated.
    20,000 Gallons, 33.9 x 19.9 free form inground plaster pool 7 feet deep with Spillover Spa, Salt Generator (Fusion Soft),Heat Pump, Single Speed 2 HP Pump, D.E. Filter. Zodicac PDA, IQ900RS Controller.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    Re: What type of Chlorine do I enter for Pool Math
    SWG is an option and that is the correct one to choose.
    Jun 2014
    15,233
    I think I understand the question now. At the top row for FC, the manual chlorine drop-down section simply won't apply to you like it would for non-SWG pools. But near the bottom row (Suggested Goal Levels), you can select SWG and your pool type. After doing that, it will update an FC "Goal" range that is listed next to the FC (row) title back at the top row. Hope that makes sense.
    May 2015
    Union, NJ
    128
    Not is not an option on the FC line.
    Quote Originally Posted by pooldv View Post
    Got it! Thanks.
    Quote Originally Posted by Texas Splash View Post
    Mar 2007
    San Rafael, CA USA
    12,082
    The above is for setting the proper goals, but if you wanted to translate an FC into the weight of chlorine gas which is how SWGs are rated, then use "chlorine gas" in the FC section or in the "Effects of adding chemicals" section. You obviously don't add any of that directly (you set a % ontime instead), but it will tell you that 2 ppm FC in 20,000 gallons is 5.3 ounces weight of chlorine gas. Since most of that FC loss is during the day, one can figure that this amount of chlorine should be generated over 8 hours so that gives a 24-hour rate of (24/8)*5.3 = 15.9 ounces weight or roughly 1 pound chlorine per 24 hours.
    May 2015
    Union, NJ
    128
    Thanks.
    Quote Originally Posted by chem geek View Post
