Thread: Advice on adding a propane heater
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Hi All,
    Now that the pool has been put up for winter I am putting my energies towards research for a 100-200000 btu propane heater. It seems like they all have some type of bad reviews. I was looking at a Hayward H series low nox 150...anybody have any thoughts?
    Thanks
    Rob
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    Re: Advice on adding a propane heater
    We added a used Jandy Lite2 125,000 BTU to our 16x4 Intex this year. Running it off propane 20lb BBQ tanks, but considering having a tank installed next year. It takes about 8 hours to heat up (we only heat it on weekends).
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Cool, there are so many to choose from it gets a bit overwhelming. Is yours millivolt or electronic?
    Cheers,
    R
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Raypak is by far a better unit hands down. I would suggest their 266K unit. You won't be disappointed.
    One big factor with this heater is it doesn't have any extra bells or whistles like a blower motor or extra boards that can go out later down the road. It is a straight forward unit.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Having dealt with pool heaters most of my life, propane can be tricky. Make sure the propane tank being used is at least 100 gals per 100,000 btu's. The biggest problem is letting the tank get to low. Household appliances run from 40,000 btu to 100,000 btu on average. Adding a 200,000 btu heater changes the game. The key is to never let the propane heater run down below 40%. I have seen many a damaged heater from low propane situations.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    We have a Pentair Max-E Therm heater. First year installed... it's been great. No issues. I would recommend based on year-one performance.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
