Thread: Contractor woes
    Nov 2013
    Fort Worth, TX
    114
    Contractor woes
    We hired a contractor to replace some deteriorating stones on our pool coping. In removing the existing stones, they cracked three tiles that they were not happy about replacing. They came Saturday to replace the tiles and in the process of removing the tiles, they chipped the plaster (?). They will be here tomorrow. What's the appropriate way to fix this damage?
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Contractor woes
    Hi Bill,
    I dont know the answer to your question, but maybe my reply here will help bump this thread and get it back to top. Hopefully, someone who knows will chime in soon.
    Divin Dave,
    Nov 2013
    Fort Worth, TX
    114
    Re: Contractor woes
    Bump
