Results 1 to 11 of 11
Thread: Mystery Stain
    Dec 2011
    Austin, TX
    38
    Mystery Stain
    For a better part of the summer I have had a mystery stain in a 4x6 area of the pool. the stain is faint, blotchy, green to tan in color and climbs the corners up onto the wall. I'd have said that it hasn't spread or changed at all, but i am now noticing a small similar stain in another, deeper area of the pool. The stain does not appear to brush off at all, and the initial area doesn't seam to grow or change.
    During the summer, my water has been clear, and ,in general, has been maintained in recommended specs. There was a period, however this past spring where things got out of control.
    I have shocked several times and have seen no change in the area. currently, I am shocking again, and brushing the area daily. Does anyone have any suggestions or recommendations as to what this is or how I can treat it? I have tried to take photos, but no matter what angle I use, they don't really come out well.
    Thanks, Chris
    Currently
    pH7.5 (FYI it CHRONICALLY rises to 8.2)
    FC17.5
    CC 0.5
    TA 60 (store says 100)
    CYA 25 (store says 60)
    CH 450 per the store (I can't ever seem to get a color change in my test kit)
    Built 2012: 14x28' free formed IG gunite with 4 person spa. 11,000gal, Hayward 2 speed Tristar pump, Hayward 420sq ft cartridge filter , auto tablet chlorinator (I use BBB), 250BTU Hayward heater, quartz pebble finish, LED lighting
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: Mystery Stain
    How about grabbing a handful of Vitamin C tablets and holding them against the stain to see if it changes it. If it is a metal stain it should improve under the Vit C.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: Mystery Stain
    ...and posting a pic if possible....
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Dec 2011
    Austin, TX
    38
    Re: Mystery Stain
    It took me a few days to accomplish, but it appears as though the Vitamin C tablet DID remove the stain where I rubbed it. As I indicated, the pictures are difficult to see, but you can jus make out the shadow of the blotchy stain.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,637
    Re: Mystery Stain
    I see it. I am glad to hear the Vit. C worked!
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: Mystery Stain
    If Vitamin C lifted it, it's metals. Could be that someone used copper algaecide in the past, or some kind of miracle low-chlorine-patented-unique-but-not-really metal ion system. Or even worse... you drove the pH super low using trichlor for so long that you dissolved the innards of the heater. Pool School - Metals in the Water and Metal Stains
    Dec 2011
    Austin, TX
    38
    Re: Mystery Stain
    Thank you folks!
    Richard ,
    Thank you. i am going to confirm once more with a larger dose of the vitamin c. I am going to fill a sock full of crushed tablets and sit it on the stain. All of those causes you mentioned seem implausible. Are there other ways that I could be seeing metals, or is it less likely that I have metal? The pool is 3 years old and has never had algaecide or had tricolor. I am the only owner. My struggles with pH are only that it is CONSTANTLY on the rise. i add Acid every couple of days. Incidentally, right in the location of that stain.
    Thanks
    Jul 2012
    Tallahassee, FL
    30,637
    Re: Mystery Stain
    Quote Originally Posted by boston2austin View Post
    ???????????? I do think we have a clue here!!!!!!!!! Not sure what the clue says but...........it is a clue! LOL
    Kim
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Re: Mystery Stain
    I do not believe that stains are caused by acid. I thought it was possible that acid additions and chlorine could possibly cause a chemical reaction and could cause staining, rust, etc.
    Chem-Geek confirmed in a very long thread, this is not the case and that PH, if allowed to drop very low could cause problems as water becomes very corrosive. MA should be added to the pool just as if it were chlorine, in front of a return to shoot in the pool. I have found the smallest stains on my white steps, and even Vitamin C does not remove them. Have no idea how they show up. There are no metals in my water either (tested many times). Chances are that the stains are related to something else.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jul 2012
    Tallahassee, FL
    30,637
    Re: Mystery Stain
    Well darn! Hummmmmmmmmmmmm it is right in front of the return so........could be something coming out of the filter or just how the sun does or does not hit that spot in the pool??????????
    Kim
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Mystery Stain
    Feel the plaster in the area. If it's rough in the area of the "stain" then that may not be a stain so much as plaster deteriorated from the acid. Rough plaster can look darker and can also get algae more readily.
