Thread: Pool timer problem
    gregg4565's Avatar
    Jul 2013
    Tucson AZ
    12
    Pool timer problem
    So i have a T104 automatic pool timer. It came with the pool and is aprox 10 yrs old.
    The problem is that anytime the pool is suposed to turn on the breaker for the pool timer trips and the pool doesnt turn on. I have never had any problems with the timer in the past, so im wondering if these go bad? Is there a way to test it ?
    Thanks
    Gregg
    11,000 gallons
    in-ground
    Hayward sand filter
    1 hp hayward energy flo rs
    Built in 2000 (aprox)
    Swim pure plus SWG
    Jun 2014
    15,292
    Re: Pool timer problem
    Does it make any difference if you flip the timer's manual lever over to the manual setting to override the timer portion?
    Jun 2015
    Wildomar, California
    423
    Turn the breaker off first, turn the timer to on position, then turn the breaker on and see what happens then.
    gregg4565's Avatar
    Jul 2013
    Tucson AZ
    12
    So after doing some research on here (couldn't find anything before i posted this) it turns out to be the little on/off tripper pins were bad. I went to ace hardware got some new ones and seems to be working fine . I guess they wear out over time.
    Thanks for the help TFP!
    11,000 gallons
    in-ground
    Hayward sand filter
    Swim pure plus SWG
    Jun 2014
    15,292
    Bad pins? Huh. I've got to try and remember that one. Glad you got it taken care of.
