Results 1 to 8 of 8
Thread: Polyquat question and more...
    May 2015
    TN
    312
    I am going to let a pool company blow out my lines and put the cover on my pool. I am going to bring it to shock level myself, and have it to the proper drained level before they get here. So, all I will do is pay them to blow out lines and cover. (I just don't want to deal with it this year and want to know it is done right)
    Tell me if what I plan to do is correct:
    Before they come I will get it to shock level and let it fall halfway. (I know it will take some coordination with having to know what day they are coming)
    Add Polyquat, then do my drain to below returns (I am not sure what chems they add to close and how it interferes with the BBB method we use)
    Let them blow my lines and out cover.
    Am I missing anything?
    Next question... I looked up Polyquat on Amazon and seen nothing that said Polyquat but I did see that everything was an algae preventer with the numerical of 60. Same thing? If so, how much do I need to order for my pool? Specs below.
    Last but not least: THANK YOU GUYS so much for all of your help this season! I am a true believer in this method and literally have done nothing but added bleach each day and vaccum weekly. This site is awesome!!!
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Re: Polyquat question and more...
    Here is what I use based on help from other members.
    Amazon.com : Kem-Tek KTK-50-0006 Pool and Spa 60-Percent Concentrated Algaecide, 1 Quart : Swimming Pool Algaecides : Patio, Lawn Garden
    Allow the polyquat to circulate for 24 hours (keep filter and pump running for 24 hours to circulate in water).
    Then allow them to close the pool. Please make sure they do not add any other chlorine products or it will affect the polyquat 60.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    May 2015
    TN
    312
    Quote Originally Posted by Catanzaro View Post
    Thanks!!! I will order that.
    Jul 2015
    Western NC
    115
    Quote Originally Posted by lindz18 View Post
    Add Polyquat, then ...
    Add Polyquat, run pump for 24 hours, then ...
    I bought this one. Amazon is cheaper at $21.21 including shipping with Prime, but they are currently out of stock.
    I plan to use one bottle, i.e. one quart.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    Catanzaro's Avatar
    Jul 2014
    2,256
    Yes, I ordered 2 for the free shipping ($21.21), and used one at a friends house as we closed him pool. If not, you can always find something else on Amazon to have the free shipping for orders over $35. If you have Prime, should be in 2 days.
    May 2015
    TN
    312
    Got the local pool store lined up to blow the lines and put cover on only. 95 bucks. Worth it to me to know it is done right and I don't have to tug on cover.
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Quote Originally Posted by Sparkle View Post
    Looks like it's back in stock.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    465
    Don't forget to brush and vacuum before you drain the water.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 29k gal., 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
