Results 1 to 7 of 7
Thread: Testing--AKA Titration--
    EvanWilliams's Avatar
    Sep 2015
    Plano,Texas
    28
    Stupid process question but here goes.
    When testing and adding the reagent (titrating) where is your end point?
    Using the speedstir is frequently see the first hint of color change then a small but easily noticeable change, then one drop or more and a full color change.
    I'm tempted to take the middle ground. Drop----tiny and slowly expanding faint color change then one drop or more gets me an easily noticeable color change that is still light but larger.
    I don't my old eyes could be that precise without the speedstir.
    any input appreciated.
    IG: 15000 Gal. Plaster. DE. 1992. Spa. Pump----(Will check brand and update). Heater. TF-100 Kit w Speedstir
    38,251
    Re: Testing--AKA Titration--
    You always add drops until the last one causes no further color change and then do not count that last drop.
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    I've wondered about this too, thank you for asking the question!
    Pool Completed 8/2015 18'x36' Gemini shape 3.5' - 8', 19,200 gal IG vinyl, Hayward Max-Flo 1.5 HP 2-speed pump, Hayward Pro Series 300-lb sand filter, Hayward AquaPlus SWG, NO Autofill, Dolphin M400 robot, Taylor 2005 test kit, 434 gal Bullfrog A7L spa
    Sep 2015
    Plano,Texas
    28
    I ges that makes sense because we are looking at quantity using known volume.
    Were we simply doing qualitative--is it there or not--positive or negative----any color change would do.
    Simple I guess but my old atrophied brain needed to have it articulated again.
    Thank you.
    Mar 2007
    San Rafael, CA USA
    12,082
    Technically in quantitative chemistry one has the endpoint at the halfway point between the color before vs. after the endpoint. However, there is enough error in the test kits and for simplicity the rule is to keep adding drops when there is a color change and not count the last drop that shows no change.
    Jul 2014
    Hope Mills, NC
    567
    Here is how I do it...
    Add drop (as you stated with the Speedstir sometimes there will be a slight color change that will go away quickly, that is not anything to worry about) if color does not change, add another drop. Continue until there is a NOTICABLE change. If at 6 drops, the solution turns from blue to faint pink, that is not the color you are looking for. Add another until that solution changes to bright red, say at 7 drops, now add one more...if the bright red color does not get brighter, that was your endpoint, not the 8th drop, but the 7th, it was the last drop that did anything.
    Also, do not wait for any long length of time between drops, no more than a few seconds. Solutions can change again given enough time and buffers.
    Since I started going that extra drop or two, my results have been very consistent.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Sep 2015
    Plano,Texas
    28
    Thank you all. I learn every time I come here.
