Thread: Pool heater not sensing pump
    Sep 2015
    Old Westbury ny
    2
    I have a jandy lite 2 pool heater using an external pump which intermittently stops sensing that the pump is on so it shuts off. Any help would be appreciated.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Pool heater not sensing pump
    So the Jandy Lite2 is NOT controlling the pump with the extra board inside the heater? If so, then it sounds like you could have an issue with there not being enough flow for it to sense or that the flow switch is shot. I would first make sure your filter system is clean and any valves that you might have in the system are turned to the correct position. Once that has been accomplished, then you can go about checking the pressure switch in the heater. You can disconnect the two wires going to it and place a jumper wire between the two of them. If the unit fires up, you can pretty much assure the switch is bad. But first, make sure your filter system is clean and that if you have any valves in the system, they are turned to the correct position.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Sep 2015
    Old Westbury ny
    2
    Great. Pretty sure the filter is clean but will try that first. Then try the pressure switch. Thank you for your help.
