Thread: Closing AGP in NY - cover or not? There's this dog...
    Jun 2015
    Wantagh, NY
    7
    Hello - it's about the time I normally cover my pool. Last year our new dog spent the winter on top of the frozen pool, eventually chewing through the solid cover and popping the pillow. Made spring opening an adventure. I figure my choices are buy another solid cover and pillow and fence off the dog's access or use a mesh cover until all the leaves have fallen? Any recommendations or suggestions? Pics of pool area (with partial deck, trees and dog) here for reference. Thanks!
    Jun 2014
    15,221
    Re: Closing AGP in NY - cover or not? There's this dog...
    We have 6 dogs. They are just like our children. After having our pool installed, we quickly realized we had to fence our pool off because those knuckleheads would either go in on their own (without adult supervision), , or one would get bumped into the pool by accident while they were running around and playing. Some of our dogs don't like the water, so that's not good. I had a friend whose dog fell under their cover and drowned. Since your pool is an AG, and you only have a ladder for people to get out, you might have to ask what would happen if your dog went through ice or a cover with no one around? Could he get out? If so, would he tear the liner trying? The cover options are great to prevent leaves and debris from going in the water and making clean-up easier, but for your dog's safety, you might want to consider a barrier.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    +1
    As a multi dog owner as well i would think the dog comes first
    If the pool is tall enough that the dog cant jump up on it you maybe able to get just away with preventing him from getting up on the deck?
    If he/she is a jumper you need to keep him away from the pool.
    You also have to give so thought to the amount of snow we've been getting on Long Island.
    I have a 6' fence around my pool and last winter some of the drifts were almost to the top of the fence!
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Block it off. It looks like it would be easy to do with your set up. Fence and gate on the equipment side. Gate at the BOTTOM of the of the steps to keep her out unless you WANT her in/by the pool.
    Your backyard is very pretty. LOVE the set up!
    Kim
    Jun 2015
    Wantagh, NY
    7
    Thanks all for the suggestions. I agree with the importance of removing access to the pool for the dog. We will be blocking it off. Thankfully she's not a jumper! Part B of the question: covering the pool or not. Given that I'm in a cold-dominant climate (Long Island, NY), would you recommend covering the pool or is leaving it open OK?
    Jun 2014
    15,221
    Either is fine, although for those who have lots of trees nearby, covers have become quite popular. At the very least, consider a mesh net that will contain a majority of the leaves and debris to save you some effort down the road. There are lots of such discussions this time of year, and you can find many of them simply by typing the word "pool cover" in the search button on the home page. Good luck!
