Thread: Pump Won't Prime
    May 2013
    Boynton Beach Florida
    16
    Pump Won't Prime
    Can someone please help?? I went away for 10 days and came home to a half green pool with bubbles coming out of the return lines.I Cleaned the filter and pool and the same thing happened so I replaced the pump thinking it burned out. With the new one in the same thing is happening any ideas ?If there is a leak how do I find it ? Thanks
    14K gal,In,plaster, cartage filter 1hp pump zodic g3 cleaner swg.
    Jun 2014
    15,255
    Re: Pump Won't Prime
    Here are a couple pages on leaks:
    Pool School - Suction Side Air Leaks
    Pool School - Leak Detection
    Just to clarify ... so is the pump running? You have power to the new pump correct? Is the pump basket filling all the way to the top with water? Check those pages above first and maybe after that with a little more info we can give you some more guidance.
