Results 1 to 8 of 8
Thread: GFCI Question
    Jul 2015
    Ohio
    14
    GFCI Question
    We are in the process of wrapping up our new pool install and are now completing the hookup for the electric. Do we need a GFCI breaker in the sub-panel? Also, what size breaker should be ran to the pump (Hayward VS Superpump).
    Any recommendations appreciated.
    Angela
    16x32 IG/vinyl liner steel wall, 1.5hp Hayward SuperPump VS, Hayward swimclear 325, 1 Hayward Colorlogic 4.0, automatic chlorinator.
    Jun 2014
    15,212
    Re: GFCI Question
    Hi Angela. We have many seasoned electrical experts here who will verify that for you. In my novice experience, you certainly do need a GCFI circuit. Where that GFCI is controlled can vary between the outlet itself (GFCI trip) or the breaker. I did mine at the breaker in the panel. Typically they are rated for at least 20 AMPs, although all of your equipment may be used to calculate the amount of amps drawn at its peak to verify. Let's see what others have to say. Always a good question.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: GFCI Question
    IMO, GFCI is not necessary for your pool pumps but it doesn't hurt (save for the $$s). Surge protection isn't a bad idea and almost mandatory for VS pumps due to their sensitive electronics.
    GFCI IS necessary for your pool lights since those are in contact with the water. The idea is the same about dropping a hairdryer into the tub.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jul 2015
    Ohio
    14
    Re: GFCI Question
    Thank you both. That is very helpful! This site is a lifesaver
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: GFCI Question
    Oh, a 240 V-20 A breaker should work fine for 90% of the residential pumps out there. Some of the smaller ones like 1 HP or less can run fine on a 240 V-15 A breaker.
    Certainly, these can be GFCI if you want.
    Just remember that 20 A needs at least #12 wire while 15 A needs at least #14 wire.
    ----Chris----
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: GFCI Question
    A GFCI breaker for the pump is required by current NEC.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: GFCI Question
    Thanks for that, John. I just looked it up. It almost seems that GFCI is the rule rather than the exception these days. I shall upgrade my suggestions! Seems that all equipment within 20 feet of a permanent, in-ground pool that uses 120 V or 240V, 15 A or more, requires GFCI protection. This is per 680.22(A)(5).
    Looks like I'll getting all new breakers in my sub-panel!
    ----Chris----
    Jul 2015
    Ohio
    14
    Re: GFCI Question
    Found the 20 A gfci we needed and we will definitely take your advice on the surge protector. We just lost out aerator control panel to a spike. Thanks again. Looks like this project might be done very soon.
