Thread: Hayward Heat Pro Heat Pump Flashes error code LP
    Jul 2014
    Northern Cincinnati, OH
    56
    Through online searches this stands for Low Pressure but sounds like it can be caused by a bunch of stuff other than just a freon leak, like a bad fan motor, start capacitor, control board, etc., etc. Since I don't have A/C gauges, would like to try to cross off anything I can before calling a repair person. I was hoping perhaps someone could give me some pointers on where to start and how to test things if possible. I know on my house heat pump I could try to start fan capacitor by spinning the fan at start up, but my pool heat pump does not start up for a few minutes, so not sure when/how to test that. The model is a Hayward HeatPro HP11002. Any help is greatly appreciated!
    NJ
    291
    Re: Hayward Heat Pro Heat Pump Flashes error code LP
    Have had the same issue. You could just jump out the low pressure switch and see if it will start up. Don't leave it that way for a long time or you could cause some damage.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    canpool's Avatar
    Jul 2013
    Canada
    41
    Hopefully someone chimes in with more info .. What I can add is .. Mine went on the fritz this spring not heating and throwing LP code. Capacitor was the culprit. Luckily or unluckily .. it was only 1 season in use and was covered 100% by warranty .. If you know what to look for I assume it's an easy fix. Tech was in and out in under a hour.
    to add here's a data sheet I had saved from looking at my issue:
    http://www.nuccibros.com/sec_0934drr...ting-guide.pdf
    Kafko 15x28 Rectangle granite grey liner pool - Kafko 8 foot granite grey steps / Kafko 8 foot granite grey sunledge - Hayward Equipment - Kafko Safety Cover - Beachcomber 750 hot tub
    Jul 2014
    56
    Thanks for the replies. So jumped the low pressure switch and it fired up, so that let me know the fan, capacitor and controls were fine and it was either the low pressure switch itself or it was low on refrigerant. I put a set of gauges on it and there almost no pressure (high and low sides) so it has some kind of leak. Not sure what could have happened. It worked this spring, but since then has sat with the power turned off. I do not mow/weed-eat next to it so not sure what could have happened.
    I noticed this takes type R-22 refrigerant (6lbs) which that alone would probably cost a couple of hundred dollars in material, let alone finding/fixing the leak if possible. Wondering if this is even worth having someone come look at or if it is headed for scrap heap and best to just use the service call money towards a new one...
    Jul 2014
    56
    Many thanks for that data sheet as well by the way!
