Thread: Micro Mesh cover not draining (with pics)
    Jul 2013
    Long Island, NY
    532
    This is my first time using a micro mesh cover for my AGP. I was under the impression the water was supposed to drain but as you can see below its just puddling when I spray the hose. The water level is about 6 inches below the cover. Am I doing something wrong? It's pulled pretty tight as you can see with clamps. Any ideas/thoughts?
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Re: Micro Mesh cover not draining (with pics)
    I have a mesh cover, and the directions say it should sit on top of the water. Some of the water from the pool will seep to the top of the cover, and that is ok. That is what keeps it on the water when it is windy.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
