Thread: New 12v pool light not working.
    Sep 2015
    Millbury
    2
    Ok, so I just wired up my new 12v pool light and it's not lighting. The light is wired to a pentair pool light transformer. I am getting a good 122v in. When I put my meter on the low voltage output I get the following 2 readings. 13.5v from common to 12v hot wire. 7v from ground to 12v hot wire. I get that same readings regardless if the light is connected or not. My ground connections seems fine but I would expect similar readings from common to 12v hot as I would from ground to 12v hot? I have not tested the output at the light because the different readings I am getting at the transformer have me suspecting a transformer issue.
    Any thoughts?
    Jun 2012
    western NY
    1,559
    Re: New 12v pool light not working.
    Transformers usually will have two output wires. You should get your output reading between those two wires. Unless it is specified, the output should be AC "Usually" the output wires are not identified as hot/neutral. Since there is no ground conductor tied to the output side of the transformer, I am surprised that you are getting a reading at all to ground from the transformer.
    When you wrote this... I get the following 2 readings. 13.5v from common to 12v hot wire.are you measuring between the two output wires? or are you going from one output to the supply common/neutral?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Sep 2015
    Millbury
    2
    Quote Originally Posted by danpik View Post
    I think I am good to go. I guess I should have opened the light up to begin as the bulb was not screwed in all the way. For good measure I took a reading from the light fixture and got 13.2V. Thanks for the reply and BTW I was measuring from the output of the transformer hot/neutral when I got the 13.5 at the transformer.
    Thanks again.
