Results 1 to 8 of 8
Thread: Too much suction...vacuum hose bending...
    Oct 2012
    McKinney, TX
    50
    How to stop this? Vac head has so much suction that the head is tough to move across the floor at times. Hose will kink at the skimmer or if the hose gets curled...due to high suction.
    I have drilled about a 3/8" hole in skimmer plate but still too much suction.
    Fiberglass pool with VSP.
    Thoughts??
    Liberty Pools - Lincoln
    McKinney, Texas - Built Jan 2015
    10,800 Gallons Fiberglass IG; Hayward SP3200VSP; AquaRite T-Cell 3 SWG; Hayward C17502S Cartridge Filter; TF-1000 Kit on it's way
    Aug 2014
    Northern IL
    4,615
    Re: Too much suction...vacuum hose bending...
    Do you have any valves near your pump so that you could adjust the water suction?
    Oct 2012
    McKinney, TX
    50
    Only valve is for the deck jets but it's on the return side. Would that help?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by mckinneymagnum View Post
    No. If the main drain was plumbed to a valve you could release some of the suction that way.
    How worn out is that vacuum head? If the wheels have shrunk and the body sags, that may be part of the problem. If the head is newish, then try drilling another hole in the vacuum plate.
    Oct 2012
    McKinney, TX
    50
    Head is about 6 or so months old
    Jun 2015
    N Tonawanda, NY
    476
    Turn down the pump speed?
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Aug 2014
    Northern IL
    4,615
    Another thought if no other ideas pop up. Thinking maybe the hose might be weak in that one spot? We once had a hole near one end in our hose and had to cut it out and reattach the fitting.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    What vacuum head are you using?
