Thread: Test water from tap?
    Mar 2009
    Woods of North Florida
    148
    We had our new pool installed yesterday and are in the process of filling it up with a hose. Can I use the water from my kitchen tap to test to see where we sill bestrting from or will I need to wait until the pool fills up, run the pump, and then test? I know it is originally the same water, but does the pool liner, filter sand, etc. change the water? Thanks!
    For now I'm going to change my signature to add my pool info!
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
    Re: Test water from tap?
    You can test the water straight from the tap. Let it run for a little while before collecting a sample to test.
