Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Water Temps vs. Running Pump until October
    May 2013
    Hauppauge, NY
    26
    Hi all. I have read the awesome primer on how to close your in-ground pool, and although I have been closing mine for 13 years now, I am debating following the advice and waiting until the water is "solidly below 60 degrees."
    I have a mesh LoopLoc for an 18 x 36 vinyl pool.
    However, that does present its own set of problems. First, we've had an unusually warm September here on Long Island, and the water is still in the mid 70's.
    We expect temps to be in 70's for highs and lows in 50's for a few nights starting on Sunday, but then rebound to close to 80 again next week.
    I really don't have the coin to run that filter for another few WEEKS waiting for fall to arrive, so the BIG question really is, is there are major issue with closing it now? Won't algae growth be somewhat slow and minimal after shocking, balncing, treating, etc. as the sun's angle lowers and the cover masks most of the sunlight or am I deluding myself?
    I have always closed it well before today's date and have had varying results in spring, MOSTLY because I opened it too late.
    Thoughts and opinions are very welcome!
    JoyfulNoise's Avatar
    May 2015
    13,225
    Re: Water Temps vs. Running Pump until October
    Algae growth rates are predominately determined by two things - light and heat. Light is easy to take care of if you use an opaque cover.
    Figure 3 in this paper shows the growth rate of lake algae versus temperature. For some strains of algae, growth rates completely collapse below 15C (59F).
    So waiting until your below 60F to close and opening before the water reaches above 60F will have a huge impact on the algae load in your pool.
    Matt
    May 2013
    Hauppauge, NY
    26
    Thanks for the insights. I just hate to continuously pour money into my local utility company. Can I lessen the amount of hours I run the pump this time of year without an issue? I am running it about 8 hours a day right now.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Many members here find they can run their pump as little a 4-6 hours even in prime swim season. This does somewhat depend on your equipment though. It would make it easier for us to give you good answers if you add your location to your profile and put your pool profile in your signature.
    Pool School - Read This BEFORE You Post
    Jul 2013
    Long Island, NY
    155
    I'm on Long Island as well and our pool will be up to 88 deg F today (w/heater) and we have company coming next weekend to swim as well, so my guess is we'll not be closing until the end of October with the warm weather this summer. I think you could get away with less pump time as long as you keep the chlorine levels up.
    20x40 in-ground Bella Blue Pebble Fina pool w/diving board, 1 HP Hayward Superpump, Raypak RP2100 335k BTU NG mV heater, Pentair Quad DE 60 filter, Pentair 261173 multi-port valve, Stenner 45MPHP10 pump w/15 gal tank, Intermatic ET1125CR dual electronic timer, 1.5" lines, two skimmers w/socks, Poolskim, vacuum line, ColorQ Pro 7 kit, TF-100 kit, speedstir, 2 froglogs, Dolphin Discovery Robot. Wine is the answer, what was the question?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    If you cover the pool, you certainly can run the pump less time. You only need to run the pump long enough to skim teh water, and to provide enough circulation. 2 hours would probably be plenty if the pool is covered.
    Quote Originally Posted by Swataz View Post
    Divin Dave,
    May 2013
    Hauppauge, NY
    26
    I updated my signature, so hopefully it helps some of this great feedback. Thanks all.
    18' x 36' Inground Pool
    Vinyl Liner
    Hayward DE3620 filter
    1 1/2 HP pump
    May 2013
    Long Island NY
    419
    I'm on LI also. I cover my pool as soon as the leaves start falling, regardless of temp. I let the pump run 2 or 3 hrs a day .
    When the water get cooler I blow the lines and pull the pump. With the cover on your pool will use very little chlorine but you still need to keep an eye on it.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    May 2013
    Hauppauge, NY
    26
    The thing that's confusing me right now are the posts regarding running the pool filter with the cover on. Once I go through the rigamarole of putting that looploc on, I'm DONE. There is no filter, no pump, no nothing. That is the final step in MY process of closing my pool.
    Vinyl Liner
    1 1/2 HP pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I run my pump 365 days a year without going bankrupt. Three hours a day is plenty for my pool. Keep pH and FC in range until the water is solidly below 60. I'll tell you from experience, when the water gets cool, FC usage goes way down. The bleach you use and the electricity to run the pump a couple hours a day will be more than offset by the savings on bleach you don't need to use next spring to clear the swamp.
    When plunging your arm in the pool to get a sample gets painful, then close.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,186
    Well, can you re-order how you do things? The colder the water the better for a clear opening.
    Folks are just trying to let you know what works for them. How you use/modify the information used is up to you to use in your situation.
    Support the site
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Im on Long Island as well and will be closing the pool in 10 days whatever the temp. To be clear if its looks like it will be still be above 60 I'll just put the LoopLoc on and continue to test, add needed stuff and run pump until it gets colder. Since I have my pool repair guy do the closing i'm scheduled to be his last one before he goes south for the winter. when he come back Ive already exposed the returns & skimmer as well as drop the water level. All that has to be done is blowing the line, remove pump, Gizmo etc. Than just Snap the open parts of the cover back on. Opening an non green pool is a good thing!
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    May 2013
    Long Island NY
    419
    The reason people put there cover on and run the pump is that they are waiting for the water temp to drop. They know that algae has a hard time growing in cold water.
    May 2013
    Hauppauge, NY
    26
    Don't misunderstand me. I am very grateful for all the feedback.
    I think I need to clarify why it's not very practical to cover and then close later. Before I purchased my home 13 years ago, the previous owners had an issue with the main drain and sealed it off, making it impossible to use that mechanism as a means of emptying my pool. So, I need to basically drain as much as I can through waste and use a manual vacuum and hose to drain it below the skimmer line. I actually vacuum it as a means of getting the last bits of debris out and just leave it in there to continue draining.
    This is what makes it impractical to cover and then drain or close afterward. The main drain's closure is a large pain in my butt.
    I suppose I could leave some anchors unattached on either end and see if I can work around them to close it.
    Vinyl Liner
    1 1/2 HP pump
    May 2013
    Long Island NY
    419
    I see, your saying your main drain doesn't work. There is another way with your garden hose. You can use your garden hose as a siphon and drain water from your pool. It takes a while, but it works good.
    May 2013
    Hauppauge, NY
    26
    I should also mention the pool temp is still 78 degrees! Swimmable, even.
    Yes, thanks, I've used that method in the past for a slow drain.
    Vinyl Liner
    1 1/2 HP pump
    Jul 2013
    Long Island, NY
    155
    Wow Swataz...I see you're in Hauppauge. Very cool, I work in the Hauppauge Industrial Park. Ever go to Ciro's Pizza at 347 and 111? Been on LI all my life and never had such a good slice anywhere.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Pulling your cover OFF at night and running the pump for a few hours will help with cooling it down should that be your goal. You lose a lot of heat at night to the cooler air temps. If you grab a one or two ninety degree 1.5" fittings at a big box store and replace your "eyeballs" with the 90's and aim the return water up, it will do even more to lose heat.
    Solar Blanket, Well Water, Borax Added. 68
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    I actually have my pump running for 5 hours a day now. Although, I have good circulation. About a month ago, I went from 12 hours daily, down to 11, 10, and so on. I am finally down to 5 hours per day. Each cycle, the chlorine drop test increased accordingly (Just to make sure that CC is still registering at 0). At this point, I am watching my chlorine levels and combined chlorine levels a lot closer to make sure that the 5 hours are sufficient. I am closing my pool in the next week or so. NJ weather is not too far off from Long Island. I do not know how many hours you are at now, but you definitely do not need the same amount. The mornings are extremely cooler. So far so good and test results are showing to be favorable. Of course, there has been no swimming activity. Keep an eye on water clarity.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
  20. Back To Top    #20
    Jun 2014
    Long Island, NY
    340
    One thing you can do is to put a sump pump in one end of the pool and the end of the discharge hose at the other end of the pool. this way you can remove your pump, blow out your lines & put on the cover. you can rhen add whatever Chem's you want and use the sump to circulate the water.
    I did this last year while I was waiting for my new VS pump to be installed. Red circle is the pump hose leaving the pool and the blue id the discharge
    Also as pool pump run costs are a concern of yours right now PSE&G LI has a $350.00 rebate if you get a approved VS pump. Thats more that 50% of the cost of a basic VS pump. My old superpump used over 2000 watts running, my new SuperPump VS uses about 160W most of the time & about 650w when i need to run the heater or backwash
