Results 1 to 19 of 19
Thread: New member from Australia
    Aug 2015
    Newcastle, NSW Australia
    14
    Hi All,
    Just wanted to say hello and thank everyone for an excellent and informative forum.
    Reasonably long-term pool owner (15 years) but only new to this forum.
    After having to replace my cartridge filter tank every 5 years or so due to water leaks developing, I've recently had the plumbing re-jigged to use two pumps - a 3-speed Eco pump to drive the filtration (and dramatically reduce the load on the cartridge filter) and the existing 1.5hp pump now only powers the Vantage infloor system. Hopefully also save some money on electricity as the large pump now only runs for about 90 minutes each day.
    Having done this and seeing that the water is beautifully clean after the new filter was installed, I decided that perhaps I should stop being lazy and throw away the test strips that I've been using for the last few years and look after the pool properly. After a bit of searching, I discovered this site and as a result, acquired a Taylor K-2006.
    I've only used it once and discovered that the test strips haven't been entirely truthful. No surprises there. The Taylor is a remarkable test kit and very straightforward to use.
    So now I'm slowly bringing up the TA from 40ppm. (The test strips were suggesting a value closer to 80ppm.)
    Spring has arrived here and my wife is keen to start swimming so I'm working hard to show her that the expensive test kit is worth the money.
    ~ Paul ~ Compass 11.8m Riviera inground salt water fibreglass/ceramic composite with Paramount Vantage Infloor. (55,000 litres/14,500 gal)
    Dave Chloromatic Chlorinator (SWG). Davey Crystal Clear CC175 Cartridge Filter.
    Davey 3 speed Eco Pump for filtration. GMC 1.5hp pump for infloor. Taylor K-2006.
    Jun 2014
    15,172
    Re: New member from Australia
    Welcome to TFP! Happy to have you join us. You're absolutely right about those test strips. Very misleading. Great to have you with us. Enjoy the site.
    Aug 2014
    Northern IL
    4,615
    Welcome! I have to admit I am very jealous that you are opening. Our season is coming to an end. Enjoy!!!
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    How cool...now that the Northern Hemisphere is closing, we have our friends in the Southern Hemisphere opening!!
    I understand that salt-water pools are quite prevalent Down Under...at least from the literature I've read.
    Welcome aboard!
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    domct203's Avatar
    Jun 2015
    CT
    3,591
    Welcome to the forum.
    How is your pH? Don't get too hung up in the TA if pH is steady.
    How have you been chlorinating your pool? I see a chlorinator in your signature, are you using tablets?
    What is your stabilizer (CYA) level?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Aug 2015
    14
    Thanks everyone for the warm welcome!
    And apologies for my Australian terminology. As I've been reading through the posts and articles here, it's occurred to me that there are some small differences in the way we describe some things.
    It looks like what we call a "chlorinator" is referred to as an SWG. And I don't know anybody who doesn't use one for their pools so, yes, as far as I know, salt water pools are common here.
    Dom,
    pH is 7.5 and CYA is a bit low at 30. Since I've been using test strips, I don't really have an "accurate" history of pH fluctuations but I've never been concerned that it has gone way out of range. I usually add some CYA around this time of year so I'll address that after the TA is where I want it.
    Maybe I've just been lucky but my pool has always been easy to look after. In 15 years, I've only had some green algae twice or three times and a quick dose of chlorine cleared it up. Never had cloudy water. I've always guessed that it was perhaps at least partly due to the vigorous action of the infloor heads keeping the water nicely moving and evenly sanitised? I'll need to watch that now that I'm only running it for an hour or so instead of 6-8 hours a day.
    The climate is very temperate here so I never close the pool - just turn down the pumps a bit over the winter.
    Looking forward to joining in and learning.
    Name is Paul, by the way. I'll add that to my signature.
    May 2015
    Sand Springs, OK
    13
    Welcome. Looking forward to your summer posts while we look at the snow. My moms from Perth. Just about as far away from you as can be on the same continent.
    Jul 2015
    Kentucky
    1,126
    Hello Paul, and welcome to TFP. We're glad you're here.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    It'll be interesting to learn what your numbers are and how you've kept your pool up compared to what is suggested around here. TFP suggests CYA in the 70-80 range for SWG but it sounds like you've had success with it about half that amount. What is the standard around your area for the numbers?
    You might consider removing 'chlorinator' from your info and just leave SWG. 'Chlorinators' are large holders for chlorine 'tablets' or 'pucks' and some folks actually plumb those in and use them when they leave on vacation and then deal with the rise in CYA from them later. Otherwise, use of pucks is not suggested as a normal means of chlorination.
    ----Chris----
    Aug 2015
    14
    Hi Chris,
    I've had no success with CYA at 30. Sorry for the misunderstanding. Back in April we were unfortunate to experience what the local media called a "SuperStorm". Our pool received a belly-full of mud and dirt and large amounts of rainfall and wind-blown vegetation. Over a period of two days, I was forced to drain water from the pool several times to prevent it overflowing. As a result the water balance literally went down the drain.
    Following that, the cartridge filter failed and I've only recently got it (almost) running again. I've always run the CYA at what the test strips suggested was around 60-80. At least now I can measure it with more confidence.
    Once I've raised the TA to around 80-100, I'll bring the CYA up to 70 or so, pH to somewhere around 7.5 and then adjust FC to around 5.
    Aug 2015
    14
    Quote Originally Posted by cwritner View Post
    My moms from Perth.
    I like Perth and yes, it's a long way from here.
    Sep 2015
    Perth, Western Australia
    6
    Quote Originally Posted by NoTan2 View Post
    How about that? I'm a fellow newbie and from Perth. Yes, it is quite nice - weather warming up but the water not quite warm enough for a comfortable swim (mines at about 72F/21C - kids don't mind but I find it a little cold).
    Agree with Paul - nearly everyone seems to have a SWG here. CYA at 70 for SWG pools is interesting. The pool company I went through (completed early this month) suggested keeping it between 30-50. At the moment mine is 30 and FC is about 4 (not that they tell you there is a relationship between CYA and required FC levels - I read that previously here).
    Water looks great so far but maybe it's early days. One of my sons has allergies/sensitivities to many things so worried a high FC level (ie. required for a CYA of 70) will cause him issues?
    In-ground, brick/concrete, vinyl-lined, 9m x 2.5m (7,925 Gallons / 30,000 ltr)
    Astral VX9T Salt Chlorinator
    Astral e-Combi EEV2 2-speed Pump
    Astral EC650 Sand filter
    Perth, Western Australia (Hot dry summers, mild winters, windy)
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    The relationship between CYA and FC is such that the effective CL level is pretty much equal all the way up. So for example a FC of 5 and CYA of 50 is same as FC of 10 and CYA of 100. The CYA is there to buffer the effects of the CL and to hold a reserve available as FC is used up from the sun and from bathers and algae.
    So, no, you nor your son will have no noticeable difference as FC and CYA are increased together.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Aug 2015
    14
    Quote Originally Posted by jbilman View Post
    Hi jbilman,
    I run my pumps in the off-peak hours at night to save electricity (unless someone is swimming when they get turned back on for the duration). So the chlorine is at the mercy of the sun throughout the day. Years ago when I discovered CYA, (the pool company certainly didn't tell me about it - as you said) I just increased the CYA level incrementally over a period of time until the FC was still at a reasonable level at the end of the day. I've always preferred to keep the FC somewhat higher than the 1-3ppm which you see recommended in various places. I found that CYA at 60 or so and FC at around 4-5 seemed to work. This was using test strips so it was pretty hit and miss.
    So when I came across this site, I was pleased to see that my empirical testing resulted in somewhere near the recommended levels here.
    Do you have a good test kit?
    Sep 2015
    6
    Hi jbilman,
    At the moment I have the AussieGold 4-in-1 test kit (that came with the pool start-up kit). I bought some test strips recently out of curiosity as it had a measure of CYA - but I won't be very reliant on those. So far I've been testing FC daily to get a feel for my setup and the PH etc every 2-3 days, and plan on taking a sample at least monthly to the pool shop.
    LFrankow's Avatar
    Sep 2012
    Medicine Hat, Alberta
    502
    Hello Paul I am curious as to how much your Taylor K-2006 set you back? I received a quote for one in Canada recently for 189.00 Cdn + taxes and shipping.
    Lou - 13.5K Gal pool, AG Intex 24 X 52"
    19" Sand Filter/1 hp pump, Aqua Trol SWG
    90 sq ft Homemade Solar panels + 80 sq ft Fafco panels, coupled with a SS heat exchanger/Hot Water Tank, Pentair SolarTouch, Taylor k-2006
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    taylor k2006c this is the commercial size
    $115 us plus $40 shipping to australia
    Taylor FAS DPD Test Kit Chlorine - SERVICE SIZE K-2006C $115.99
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Aug 2015
    14
    Hopefully you have a reputable pool shop. As you acquire some familiarity with your pool and do lots of reading here, you should be able to do most (if not all) of your own maintenance.
    Unfortunately good test kits (you've probably read the recommendations here) are hard to come by in Australia. There is one place here that sells a kit which is almost the same as the Taylor. I read in the rules that new members are not supposed to recommend suppliers so I can send you a private message if you like.
    Quote Originally Posted by LFrankow View Post
    Hi LFrankow,
    I ordered mine from the same place as aussieta provided a link for. Rather foolishly, I ordered the smaller size which was $65US plus $40 shipping. With our current exchange rate it is quite expensive in $AUD.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    I really hate that the initial cost is so high for you folks. It's like they know how important it is and they capitalize on that. Having your own kit, even if you have a SWG, is so important to being able to keep a clean and clear well balanced pool that it's worth it.
    The other thing that's important to keep in mind: Pool $stores, by and large, do not produce reliable, good test numbers. Of course there are exceptions, but they are so few and far between that it's hard to find the good one. If you take a sample and bring to three different $stores you will get three different answers, some VERY different. Along with that you will be told you need different magic potions to fix whatever they think is wrong. If you find a place that does a powder and drop test for FC, there's a chance they are okay. But that's only true if they use a clean test vial.
