Results 1 to 9 of 9
Thread: Testing Calcium
    Jun 2008
    Texas
    132
    Testing Calcium
    In previous posts readers have been advised in testing calcium that you need to keep swirling the vial for 20 to 30 seconds to mix thoroughly between drops. If your calcium level is near 300 ppm then the test would require 10 to 15 minutes. Are there any valid means to speed up the test and still achieve accurate results?
    For example, can you quickly mix the first 20 drops since you know your pool calcium level has consistently tested above 200 and pool calcium levels do not change quickly?
    If you do not mix thoroughly does the calcium test give results that are too low, too high, or just plain unpredictable?
    30,000 gallon gunite in-ground with a spillover spa, Diving board and water slide
    Hayward 1 HP Super II filter pump, Hayward 24 " Sand Filter Pro Series using zeolite media
    Polaris 380 cleaner with ¾ HP booster pump, Hayward Heatmaster pool heater, AutoPilot DIG-220 Power Supply SC-60 cell
    Testing with the TF-100 Test Kit
    donaldm823's Avatar
    Cape Coral, FL
    147
    Re: Testing Calcium
    you can buy a magentic stirrer to speed up the mixing. I bought one last year and it works great-I do not pause between drops and get accurate results.
    Here is where I bought mine:
    http://piscines-apollo.com/english_stirrer.htm
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Testing Calcium
    Steve, you can do the 'multiple drops at a time' method without problems If I know the CH is going to be 300+, I'll do 20 drops, swirl for 30 sec then 5 and swirl, 5 and swirl,, then do a drop or 2 at a time...If you get the endpoint after adding multiple drops, you may have overshot the mark You can either repeat the test and not add as many drops at a time when you get close or, if you are doing 2 at a time, just accept that you could be off by 20ppm 8)
    Luv& Luk
    -Ted
    Guest
    Re: Testing Calcium
    Quote Originally Posted by waste
    Ted, actually it can create some problems. If there are any metals present adding the EDTA titrant too quickly is a sure recipe for a 'floating endpoint' .
    a better way if you know you have a very high CH would be to use a 10 ml sample, 10 drops of calcium buffer, 3 drops of indicator, and then when you titrate each drop of titrant is equivalent ot 25 ppm CH It's a lower resolution test but if your CH above 300-350 ppm it's really all the precision you need.
    Also, it is possible to get results that are too high if you do not mix well after each drop. Often, when you take the time to do the test right you find that your CH was not anywhere near as high as you thought.
    The only preactical way I have found to speed up the test without getting inaccurate results is with a magnetic stirrer.
    Mar 2007
    4,160
    Re: Testing Calcium
    Evan
    (BAD WASTE )
    Luv& Luk
    -Ted
    Guest
    Re: Testing Calcium
    Evan
    (BAD WASTE )
    Guess I have to take you out back and beat you with that backwash hose again!
    Mar 2007
    4,160
    Re: Testing Calcium
    Quote Originally Posted by waterbear
    Evan
    (BAD WASTE )
    ONLY if one of us dresses like the pic in this thread
    Luv& Luk
    -Ted
    Guest
    Re: Testing Calcium
    Evan
    (BAD WASTE )
    Now you are scaring me!
    (anyway, I don't think they have that in my size!)
    Guest
    Re: Testing Calcium
    Steve456,
    Sorry about the thread hijack... we now return to your regularly scheduled programming...
    I believe you will find your question has been answered.
    FYI, I have one of the magnetic stirrers that was linked above and it's what I use!
    The seller is one of our members and has a great product, IMHO.
