Results 1 to 7 of 7
Thread: New Pump GUidance
    Aug 2015
    Raleigh, NC
    4
    New Pump GUidance
    So I'm very new to pool maintenance. Just purchased a house with a pool (IG/SWG). Based on reading other posts, I 95% certain the bearings on my pump or about to die. The pump is extremely loud (you can talk to someone next to you when the pump is on). Instead of replacing the bearings, I want to replace the "motor".
    Is it possible to replace only the motor?
    I would like to get a two stage motor to be more energy efficient.
    What do i need to take into considerations when determining if my current system can even support a two stage motor?
    Do you have any recommendations on a motor that will be much more quiet?
    Below is a picture of the overall pumping system. The second picture is of the pump that is going bad. Here is a link to additional pictures of the pool equipment that may be helpful. https://onedrive.live.com/redir?resi...t=folder%2cjpg
    Obviously, I'm a novice with pool equipment but I'm very mechanically savvy. Replacing the motor will not be a problem. I just want to make sure the new motor is appropriate.
    Thank you in advance for all the help!
    Jay O
    As green as they get about pools
    IG/SWG/17x30x9
    Approximately 2,300 ft3of water
    38,242
    Re: New Pump GUidance
    Welcome to TFP!!!
    You can certainly just replace the motor ... and I would certainly recommend a 2-speed version. You just have to match the high speed HP * SF (service factor) ... which is 1.5 SFHP on your existing motor ... to the high speed of your new pump and make sure the frame is the same (56J). You will also need a new shaft seal at a minimum and will need to wire in a switch to manually select speeds (a 3-way house light switch works well).
    Aug 2015
    Raleigh, NC
    4
    Jason - Thank you for the information. Is the motor frame the same as a flange? Also, do you have a recommendation on where to shop for a new motor? I have a Leslie's Pool supply down the road. For the 3-way switch. I guess you are referring to a plain switch I would get at Home Depot? If so, I guess I need to protect it from the elements as well.
    Jay O
    IG/SWG/17x30x9
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Leslie's would be the last place I'd buy a motor from. Find a local motor shop or go online.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Nov 2013
    Fort Worth, TX
    112
    Leslie's is the last place I would buy anything. I just bought two Jandy valves on line for the same price as one valve at Leslie's.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Quote Originally Posted by Billrector View Post
    They often have good prices on muriatic acid...at least in my area. But that is it.
    ----Chris----
    38,242
    Where did the motor picture go?
    One other question, what is the voltage for your current motor? All the 2-speed motors in that size can only be wired for 240V.
    I think you just need a B975 or B2975 motor ... although some I have seen indicate a SF of 1.4 and not 1.5
