Thread: Help Programming EasyTouch High Pool Egg Timer Schedule
    Oct 2014
    San Marcos, Ca
    62
    I am trying to program my EasyTouch to do a quick clean. I want it to run the pump when I turn a circuit/feature on and run for 20 minutes.
    I have tried a lot of combinations but the pump isn't lowering back to its low speed after the egg timer set time.
    This is what I have currently:
    Circuit 4, Name Pool High, Function Generic
    Pump Speed on Circuit 4 Pool High 2600
    Program 2, Pool High On, Egg timer off at 1 minute (1 minute just for testing purposes)
    When I turn Circuit 4 Pool High on the pump speed ramps up to 2600. But then it doesn't lower it back down after 1 minute (or even 10 minutes).
    12,000 gallon IG plaster
    Cartridge filter
    Intellifo VS
    EasyTouch Controller
    Pentair SWG
    22,539
    Re: Help Programming EasyTouch High Pool Egg Timer Schedule
    Does it stop the pump after it times out? If it doesn't, then you may have 'Don't Stop' set in the timer programming.
    I don't think it will do what you want it to. It's designed to stop a device after it times out. I don't think it will switch the control back to the main program. And I don't think the main program has a catchup function.
