Results 1 to 10 of 10
Thread: Weekend weather
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    Weekend weather
    Hoping to get one more weekend in of swimming..It will be hot outside, but with the lower temps at night, the water is a chilly 79 degrees..We swam a few weeks ago when water was 85 and man it had its moments..lol..Who would of thought 85 was still chilly..
    24x16 doughboy Summerville..22" Waterway "sand" 1.5 HP 2sp motor..Misty Falls liner, and wedding cake stairs..
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Weekend weather
    85 chilly? I thought you Texans were supposed to be tough!
    Isolated Spa - 345 Gallons
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Weekend weather
    Mine hit 83 yesterday. We're in REGARDLESS this afternoon and tomorrow! 83 is about my minimum for Memorial Day weekend kickoff. Might be pushing 84 or 85 mid afternoon. May have to switch to some of that German style "warm" beer though!
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    Re: Weekend weather
    lol..Yes I thought us Texans were tough too, but dang!!!!!!!!!!!!!! Even after mowing in 90 degree weather, jumping into 85 water, I had to squirm a little to get use to it..
    im sure the warm beer would help....
    Jun 2014
    15,255
    Re: Weekend weather
    Geez, my pool temp is still pushing 90. No polar dips for a while still.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    Re: Weekend weather
    Mine was as low as 75 when we got into the 50's for lows a week and half ago
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Weekend weather
    im down to 85 and the wife is already starting to not be interested. im good to about 75 degrees easy
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    Re: Weekend weather
    Pool temp dropped from 80ish to 71 over the course of the last five days here in NORCAL. Temps are suppose to ratchet back up to the century mark this weekend. The usual one last Indian Summer blast before fall officially hits. I may have to stoke the boiler on the heater to make 80 degree water, but swimming is in the forecast.
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Weekend weather
    I am testing mine right now and it is 86 with a big cold drink. Solar panels are blasting heat into the pool and it should be perfect this weekend.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Weekend weather
    Quote Originally Posted by MARCO...polo View Post
    Ditto here in South Santa Clara County, CA. It is a might bit chill in the water but it is supposed to be toasty this weekend here.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
