Thread: Anyone know this solar powered floating chemical dispenser worth to buy?
    Sep 2015
    Florida
    1
    I found a neat little "solar powered" dispenser on-line, anyone think it worth to buy? It sounds reasonable, the floating dispenser will move around pool by solar power, eliminates the "dead" spot of regular floating dispenser due to stay in one place, and not very expensive though.
    Thank you for you feedback!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,098
    Re: Anyone know this solar powered floating chemical dispenser worth to buy?
    Hello, and welcome to TFP!
    While I can't speak for the quality of this product, I will say that in general TFP doesn't recommend any floating dispenser. This is due to the fact that in general we greatly suggest members avoid using chlorine pucks as they push your CYA level up to the point that a drain/refill is required to fix this issue. The ABCs of Pool Water Chemistry article covers this further.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Welcome to TFP!
    In addition to not generally recommending the use of TriChlor pucks for the reasons Leebo pointed out, in a pool with proper circulation once the puck melts into the water solution it will quickly get mixed throughout the pool. While some pool do have areas of low circulation which need to be addressed, I'm not sure I thnk a motorized puck dispenser is the answer.
    As a new member I would invite you to check out Pool School - ABCs of Pool Water Chemistry
    Support the site
