Thread: Pump won't prime
    Nov 2013
    Fort Worth, TX
    113
    Pump won't prime
    Just replace the seal on my Challenger pump since it started leaking. Everything seemed to go just fine, but now that I have it back together it just won't prime. I have used a garden hose in the strainer basket and it fills quickly, but when I turn on the pump, it empties the basket quickly. I have tried to fill it and then put on the strainer lid and I have tried to prime it with the lid off and the garden hose running. Maybe its possible that I'm not waiting long enough?
    I don't think I put the pump back together wrong and I put new silicon lube on the gaskets. It was working just fine prior to me changing the seal.
    Ideas?
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    30,403
    Re: Pump won't prime
    Your pump cannot prime with the lid off.....ever.
    That might be a good clue. Go back and look at everything you could possibly have affected. Somewhere in there you are gonna' find a suction side air leak.
    Jun 2014
    15,008
    A couple weeks ago I had the same problem. I got so frustrated I actually walked away from everything for about 5 minutes. Came back and it primed right back up. Go figure. My pump is slightly above the pool, so I think my plumbing just needed a little time to let the water stabilize and fill the pipes. Once you've confirmed nothing silly (i.e. valve closed), you can also alternate between cycling the pump on & off briefly over few seconds with the basket lid secured. Allow time for water to travel from the skimmer/drain. In addition, some folks have no problem allowing the pump to try and prime for up to a minute or two.
    Nov 2013
    Fort Worth, TX
    113
    Ha.....same thing here. I came inside, posted here, went back outside and it primed. Go figure. I guess I did not leave it running long enough the first time.
    Thanks for the posts!
    Jun 2014
    15,008
