With your fill TA level and the extreme evaporation you experience, you will always be adding acid regardless of where your pool's TA resides. Certainly lowering the TA will be a great improvement, but at the cost of adding calcium, is not worth it.
With as high as your fill water is in calcium, you'll need to be very familiar with the CSI and how each parameter effects the end result...might as well start now. The recommended levels work great for those that open/close and drain their pool every year but that isn't the case in your situation. As previously mentioned, targeting a pH in the 7.6-7.8 range will get your CSI back where it should be, and even with a TA around 60-70, your CSI is around -0.36 to -0.45 (with rough numbers from above). When using the acid/aeration method to lower the TA, your CSI will be low since you must drop the pH to do so. This is only temporary and shouldn't be a concern. You need to focus more on where the CSI will be long term.
PH by far has the biggest impact on CSI, TA is second. Calcium takes large swings to show any effect. Plug fictitious numbers into the calculator and experiment with how the CSI changes.
