Thread: New Equipment Set Up Advice
    Sep 2012
    Los Angeles
    99
    Hi all, i am almost done with an owner/build, and I need some advice on how my plumber installed the equipment today. I put this in my build thread, but I thought that it might be more appropriate here. So basically, my plumber left two pipes unconnected to anything. When I asked him about it, he said that one of them has to be open from the filter so that the pool guys can use it to clean the filter (makes sense to me), and the second one that is open coming up from the ground he said is for the pump for the spa to get air. I have no reason to think that this is wrong, just seemed weird to have a pipe connected to nothing open to the air from the ground.
    I attached some pics so you can see the pipes that I am talking about. Any issues with these open pipes? Not sure if this makes a difference, but I have three total pumps and one blower. 1 variable speed for circulation, one 1 horsepower for the sheer descent, and one 1.5 horsepower for the spa, and the blower. Thanks for any advice on this!
    Rectangular pool 28x16 and spa 8x7, 17,000 gallons, IG, Tropics Blue Mini-Pebble, Jandy 60 DE filter, saltwater cell, Jandy VS pump, 1.5 hp Jandy spa pump, 400k heater, 5' Sheer Descent with 1 hp Jandy pump, Jandy color LED lights. Build Thread
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: New Equipment Set Up Advice
    The line off the filter is simply a drain to remove the water from the filter.
    The air line for the spa is necessary for the spa jets to receive air to produce bubbles.
    Both are perfectly fine.
    Sep 2012
    Los Angeles
    99
    Awesome! Thank you for the reply. This forum has seriously bailed me out so many times through my owner build. I don't think that I could have done it and slept at night without these type of replies.
    One more question, what is the purpose of the blower if the spa jets are getting air from the dedicated spa pump?
    Feb 2015
    Davis, CA
    97
    Just want to say that that's a very nice clean plumbing job. Wish my PB put half the effort in to making it look nice.
    Pool Remodeled June 2015. 18K Gallon IG kidney shaped. Pebble Tec (Tahoe Blue) finish. Jandy ePump 2HP. Hayward SwimClear C2025 filter. Hayward SWG. Jandy iAqualink RS6 automation. 6 Deck Jets. Pool Remodel Link Future: Acid automation. Chlorine automation for winter. Solar panels.
    Sep 2012
    Los Angeles
    99
    Thanks diverminh. I wasn't even home for the install. I found the plumber through my rebar guy. Apparently he does only pool plumbing for a number of big builders in SoCal. I was lucky to find him, but man, he is so busy that it took him forever to come back and install the equipment. I guess that is what happens when you are good at your job.
