Thread: Liquid chlorine/bleach deals
    May 2015
    Tampa
    1
    Saw that the 'best places to buy chlorine' thread was closed, wasn't sure why. I've typically just done the 2.5 gallon refill at Leslie's, or bought bleach at Walmart. However, recently I was at Home Depot and saw they do 6 packs of 5.25% generic bleach gallons for 7.99. Despite being less potent, this is still the best deal I can find. Seems to work like any other chlorine after weeks of use and testing (of course adjusting for the lower %). This has dropped my chlorine bill a good chunk so though I'd share! I'm in Tampa, FL.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,428
    Re: Liquid chlorine/bleach deals
    Scott that is a good deal BUT make sure to check the date codes. We had one member buy bleach that ended up being 3 YEARS old! It was really just water due to age they did get their money back.
    Kim
    Jan 2012
    'burbs of Augusta, Georgia
    7,279
    My local Lowes stores their liquid chlorine outside in the sun. Not only do I not want weaker 5% bleach, but degraded bleach is even a worse bargain IMO.
    Stick to the stores with large turn over to get the freshest bleach. 8.25% is the standard now, so weaker stuff makes me wonder even more about its quality.
    Jun 2015
    SW Ohio
    5
    I noticed the closed thread just now and wondered why as well. I was going to reply that the info posted for Indiana also goes for Ohio, since both Rural King and Menard's have stores in Ohio with the same deals:
    Rural King stores: $9.99 for 4 gallons of 10%. Frequently on sale for $7.99 and even $6.99 around Memorial Day. 19.5 cents per ounce of sodium hypochlorite at $9.99. 15.6 cents per ounce of sodium hypochlorite at $7.99. 13.7 cents per ounce of sodium hypochlorite at $6.99.
    Menards: $3.99 for one gallon of 12%. 26 cents per ounce of sodium hypochlorite. On sale around Memorial Day as BOGO making it 13 cents per ounce of sodium hypochlorite.
    In fact, right now Rural King has the 4-pack of 10% for $7.99. It looks like they do have a few stores in FL, though I have no idea how close they are to you folks. If they go back up to regular price, it looks pretty close to Home Depot's price.
    I stocked up at the start of the season when it was $6.99, but only have one gallon left now. I'm going to stop in to pick up a few more in hopes that we get to use the pool once or twice more before closing.
    My pool: 18x36 rectangular IG vinyl, 3'3"-5"3", 20k gallons, installed 9/2013. Pentair SuperFLO 1hp pump, Pentair Sand Dollar SD80 sand filter.
    My test kit: LaMotte ColorQ 2056 Pro 7.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    here is a cool little chlorine calculator and makes comparing apples to apples a bit easier.
    Chlorine Price Per Ounce Calculator
    Divin Dave,
